Anyone with greddy turbo that can help
Old Nov 5, 2005 | 04:32 PM
youngpit's Avatar
Ok still having issues with the kit. (Has been tuned by turbo trix) I have replaced the cat, with bb pipe changed the plugs, put that wire that greddy sent out. Still have the gasket that they sent with it cause not sure where that goes. The problem I am having is while under load I hear a whooshing sound and the car bucks. Once I let off the gas it stops. If I am under boots or not every once in a while I get the check engine light blinking. anyone else having this problem please let me know what you did to fix it (not taking turbo out) at this point this is what I feel like doing . I also have this that was never mentioned in the install kit from greddy https://www.rx8club.com/attachment.p...chmentid=61987
o and i think i have R flash as i got the gas tank recall fixed
Old Nov 5, 2005 | 05:53 PM
PUR NRG's Avatar
Whooshing sounds like a BOV that's set too soft. Bucking afterwards sounds like the BOV is venting to air and the mix is suddenly too rich.
________
Toyota Matrix
Old Nov 5, 2005 | 10:39 PM
youngpit's Avatar
Help
well i am F*#^ed i was out drivng i was a t a light i took off like normal got on it a little and all of a sudden i lost power in the car i could not go over 35 mph. the car still boosted . but now i have no power all hoses are connected. the car is not idleing correct either and the cel is blinking all the time.
Old Nov 5, 2005 | 11:16 PM
Moostafa29's Avatar
Storm Trooper
Oh boy, better check that engine. That doesn't sound good at all! I'll keep my fingers crossed you aren't the 3rd person in 2 weeks to blow a rotor.
Old Nov 5, 2005 | 11:23 PM
youngpit's Avatar
worst case what would it cost to fix a blown rotor. i might have a turbo kit for sale soon
Old Nov 5, 2005 | 11:29 PM
Moostafa29's Avatar
Storm Trooper
I'm not sure, but try PM'ing Saphonica and OfficerFarva. I believe they are having their engines worked on currently. I'm interested in the price as well, as a preventive measure, and maybe get a mild street port at the same time.
Old Nov 6, 2005 | 12:21 AM
adrian-1's Avatar
Ex- member.
I believe they sent you a airpump hose gasket that connects to the downpipe. Others just used their stock ones instead of the one originally supplied with the kit. It's part #49 on the turbo instructions. The hole was too small on the one they sent.
Pic between the 2 is here.
I believe people that left it in, were getting a CEL , maybe the secondary air something....?? I don't remember.
I also have this that was never mentioned in the install kit from greddy ,
It was supposed to be removed, so no need to worry. It's the VFAD actuator.
It's install section 3-7 step3 "Install a vacuum hose to the port on the intake manifold (right after the throttle) that was connected to the VFAD actuator (removed with the Air cleaner box) and connect it to the provided pressure sensor. Route the harness with the e-manage harness and connect it to
the e-manage. "
The R-flash with the stock Greddy map is bad news. It was designed for the M-flash. Call Greddy and ask about an updated map for the R-flash, no one in this forum has been able to get it yet, if it does exist.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
jDt!
Oct 2, 2015 04:04 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
