Changed transmission fluids at 30k service.
Old Nov 3, 2005 | 03:04 PM
twospoons_'s Avatar
Now it drips about 5-6 drops a night. (I placed a sheet of paper underneath the car to check). Is this due to overfilling or did they mess something up?
/twospoons
Old Nov 3, 2005 | 03:24 PM
Asmoran's Avatar
just a quick guess, but they probably didn't replace the crush washers and they're leaking.
Old Nov 3, 2005 | 03:29 PM
beachdog's Avatar
Or they didn't clean up real carefully around the fill hole. There's a ledge right below the fill hole that can hold quite a bit of fluid. Make sure that is cleaned thoroughly before looking deeper.
Old Nov 3, 2005 | 03:31 PM
beachdog's Avatar
Or they didn't remove the old crush washer and added a new one and now there are two. Depending on the experience of the tech, he might not have noticed that the old one was fused to the trans or to the drain plug. It can be hard to tell that the washer is still attached.
tallestmexican
May 1, 2018 07:22 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
iwannarun
Sep 6, 2015 01:37 PM
