Stock Alignment settings and what to run for track
Old Oct 18, 2005 | 03:07 PM
RX8SpdDmn's Avatar
Does anyone know what our stock alignment settings are?
I would like to add some negative camber to help out at the track and save the edges of my tires a bit. If anyone has any recommendations on what to run, please advise me. I have stock suspension and Dunlop SP SS Race 255/35/18 tires. I want it to still be streetable, so i can't go adding 3 degrees, or anything. Thanks a lot!
Old Oct 18, 2005 | 03:23 PM
schrottie's Avatar
If you want the car to be used both on the track and on the street, you should stick to less than 2° camber fornt and back. Set Toe-in to a slightly negative value for the front and to 0 at the back. Thats what I would start from. Oh, btw: with this kind of setup, the car will be very little fun on the road.
Old Oct 18, 2005 | 03:27 PM
PUR NRG's Avatar
Yes and you would too if you did a forum search.
________
Bho hash oil
Old Oct 18, 2005 | 05:21 PM
BlueRenesis82's Avatar
Registered Tracker
^ bwhahahahahahahahahahahah
Old Oct 18, 2005 | 06:23 PM
I'm running -1.5 deg camber , 7 deg castor and zero toe front and back........it drives fine on the street...............
Old Oct 18, 2005 | 06:37 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
i'm running -1.2 deg camber in the rear. After seeing how fast my stock tires wore out, I had it detuned in order to help the tires last longer.
Old Oct 18, 2005 | 09:28 PM
RX8SpdDmn's Avatar
Same camber front and rear?
Old Oct 18, 2005 | 09:31 PM
RX8SpdDmn's Avatar
So, you're running -1.2 in the rear AFTER the de-tune? What were you running before? What are you running in front? What's your toe setting?
Old Oct 18, 2005 | 09:56 PM
Yes
Solidtrance
22
Sep 4, 2015 12:47 PM
thewatcher101
Jul 27, 2015 09:44 PM
AussieGray
Jul 16, 2015 03:58 AM
