How much oil do you burn?
Old Oct 4, 2005 | 10:18 PM
DarkBrew's Avatar
Extraordinary Engineering
Question How much oil do you burn?
I have read the negative posts about a quart per 1000 km but what is normal oil consuption?
My RX-8 has just over 18900 km (11,500 mi) and I do not seem to be burning much at all.
BTW
I have seen 11.4 litres/100 km Hwy @ 125 km/h (US 21 MPG)
City and hwy combined 13.3 litres/100 km (US 18 MPG)
Old Oct 4, 2005 | 10:27 PM
therm8's Avatar
Bummed, but bring on OU!
I go through a quart every 2000-2500 miles (3000-4000km).
Old Oct 4, 2005 | 10:34 PM
agoodcave's Avatar
In 2-cycle terms I'm running 903:1 ratio.
Mike
Old Oct 4, 2005 | 10:37 PM
mkztg's Avatar
:( traded in my 8
I'm using just about 1 1/3 quarts between oil changes.. every 3000 miles or so.
Old Oct 4, 2005 | 11:05 PM
Astral's Avatar
Purveyor of fine bass
So far I've filled up about 3/4 quarts every 1500 miles (twice)
Old Oct 4, 2005 | 11:30 PM
Thetitanium8's Avatar
Mr. Skinny
This has not been a problem for me. I have put in maybe half of quart every 3000miles.
Old Oct 5, 2005 | 06:57 AM
skullone's Avatar
Heh, on my older Mazda Protege, I'm burning about a quart and a half every 4000 miles
Bad seals, I reckon.
I wont be surprised having to add oil frequently when I get my RX-8
Old Oct 5, 2005 | 07:40 AM
Brice-RX8's Avatar
I use roughly 1 1/2 per 3500 miles to keep it topped off.
Old Oct 5, 2005 | 07:43 AM
Chasvhill's Avatar
One quart per 2,500 miles. I top it off regularly though.
Old Oct 5, 2005 | 07:46 AM
Tigster's Avatar
RX8 ADDICTED!!!
I use about 1/2 qt every 1500 - 2000 miles
Old Oct 5, 2005 | 07:52 AM
FoxTypeR's Avatar
R is for Rotary!
That sounds like about what I use.
Old Oct 5, 2005 | 08:03 AM
c2k4-8's Avatar
Mine hardly burns any at all.
Old Oct 5, 2005 | 08:08 AM
StewC625's Avatar
Insanely Yellow
I check the oil every saturday morning with my morning coffee (I have a little love ritual with the car - check the oil, check the tires, dust the engine bay, dust the interior, the either hand wash in the drive, or head off to the car wash for a pro job). About every third check it seems like the oil level has moved off the "full" line - I then add a 3 ounce "shot" of oil into the engine at that point, using an oil filling syringe like you'd use to fill a differential housing. Keeps everything very neat and clean this way. Except the syringe which is always an oily mess! Over a period between oil changes I use about a quart or just a bit more. I change every 3000 like religion.
Old Oct 5, 2005 | 08:20 AM
Spin9k's Avatar
Momentum Keeps Me Going
I used almost 2 quarts - in just two days this last weekend
....at the track :D otherwise a qt approx every 2.5K miles.
Old Oct 5, 2005 | 08:33 AM
ucfracerx8's Avatar
Pistons are Over Rated
Question
Mine only has 338 miles on it, so far I have added 4 ounces when it had 250 miles on it last weekend. Based on that theory mine would use 16 ounces/thousand miles or 1qt every 2k, which is how often I plan to change the oil. Of course I also have not had the tach over 6k yet, so who knows? I'll shut up now :p
Old Oct 5, 2005 | 09:05 AM
Str8cold's Avatar
Average for me is about 1/2 a quart per 1,500 miles; oil consumption really is going to depend on the RPM's that you normally run the higher the number the more oil will be consumed.
Old Oct 5, 2005 | 10:05 AM
DarkBrew's Avatar
Oil consumption trends?
Is there any correlation between total miles and oil consumption?
How about driving style vs. oil consumption? Do you burn more at the track?
Has anyone tracked consumption over time?
Old Oct 5, 2005 | 10:59 AM
Feras's Avatar
the Doctor
usually about 600 to 800 miles per quart
but i did spend 2 quarts on about 80 miles at the dragon :D. This car eats oil and shoots flames when its pushed to the limit and kept there for a while.
Old Oct 5, 2005 | 11:20 AM
KYLiquid's Avatar
Oil Injection
i use about 2 qts every 3000 miles, about 1/4 qt ever 1-2 weeks.
I live upper end around redline.
Old Oct 5, 2005 | 11:26 AM
missinmahseven's Avatar
Glitchy Rotary Madness
1.5 quarts every 5000 miles.
I drive with a fairly heavy right foot.
Uses less oil than my GSL-SE did.
Old Oct 5, 2005 | 11:29 AM
eclps0's Avatar
2 quarts in les sthan 600 miles of city driving and some highway
Old Oct 5, 2005 | 06:37 PM
rx-8_or_?'s Avatar
Checking my mileage/oil spreadsheet, I've added 1 qt every 1500-2000 miles. 1500 was earlier, 2000 is later. I now have over 8k miles on the car.
Old Oct 5, 2005 | 09:27 PM
goforwand's Avatar
Raced with Joy & Abandon
Half quart every 3000 miles
Old Dec 1, 2010 | 05:38 PM
faciemus's Avatar
Oil burn
I just learned that I went through 1/2 quart after 1001 miles from last oil change. So that works out to about 1.5 Quarts in 3000 miles? Assuming I drive the same! ;P Sounds pretty close to all the other posts!
Old Dec 1, 2010 | 05:41 PM
jasonrxeight's Avatar
nice digging out old thread
btw mine burns 0.5qt every 700 miles.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
