Can not communicate with the main unit
Old Sep 28, 2005 | 09:47 PM
mikefrombarrie's Avatar
I pluged in my Canzoomer unit, turn the switch to "on" the car works.
So I tried to tune the unit with the software provided. But I get an error message "can not communicate with the main unit." I tried all the different com ports and nothing.
Does anyone know what the problem is?
Old Sep 28, 2005 | 10:00 PM
Speedrx8er's Avatar
Try changing the flow control to hardware(in device manager ports(com&lpt)) settings..
hg
Old Sep 28, 2005 | 10:11 PM
I will try that tomorrow then. Thank You!
Old Sep 29, 2005 | 07:04 PM
I did change it to hardware and no luck. I still get the error message. I tried playing around if other settings and still nothing.
Also the canzoomer unit is blinking an orange color, and when I am in netural and add throttle over 1000rpm a green led lights up.
Has anyone had this problem with their canzoomer units?
Old Sep 30, 2005 | 06:53 PM
r0tor's Avatar
did you install the software for the cable in addition to the greddy software?
Old Sep 30, 2005 | 08:47 PM
^^ I'd start with the cable software as well. You might want to remove/re-install it from your PC to be sure.....
After that...check the cable...try an other if you can borrow one.
(i am assuming you know it's not a USB cable :D )
Old Sep 30, 2005 | 10:16 PM
I tried using both the USB cable and the serial cable.
The serial is set to com 1 and the USB is set to com 3. when using the different settings I also made sure to make the changes in the greddy software.
I also upgraded the greddy software to version 1.13
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Evan Gray
Nov 24, 2015 01:00 AM
ShellDude
Oct 1, 2015 09:55 PM
Stubbs
Sep 27, 2015 04:06 PM
