clutch
Old Sep 16, 2005 | 03:05 AM
williamngRX8's Avatar
Flyboy
clutch
lets say your sitting at a stoplight for a minute and you hold the clutch down, will this cause it to wear quicker than disengaging it
Old Sep 16, 2005 | 05:40 AM
p_rx-8's Avatar
Yes. Disengage when you plan to stop for so long. One minute is long...
Old Sep 16, 2005 | 08:59 AM
Brice-RX8's Avatar
It doesn't wear the disk out it puts pressure on the pressure plate and throw-out bearing to sit there and hold the disk off the flywheel. Basically you are making the pressure plate and throw-out bearing do work when it does need to.
Old Sep 16, 2005 | 03:22 PM
Captain Amazing's Avatar
Just put it in neutral.
Old Sep 16, 2005 | 03:49 PM
ZoomZoomH's Avatar
Mulligan User
there's a reason why most people also replace pressure plate and throwout bearing at same time when replacing clutch disk
Old Sep 16, 2005 | 06:46 PM
Krankor's Avatar
Klingon Grammarian
Now let me dissent.
It is my considered opinion that the people at this site oft-times know too damn much for their own good. I am absolutely certain that they are technically correct about this clutch issue. I am also just as certain that it will make absolutely no measureable difference over the length of time you own the car. I always leave the clutch down at lights, and I've had cars for over 100K miles and never had to do a thing to the clutch. I had over 140K miles on my MX-6 (to cite a Mazda example) with zero clutch work. Yeah, if you're planning on keeping the car for a half-million miles or so, this might be an issue. Otherwise, I wouldn't lose any sleep over it.
Unless someone is claiming that there's something special about the 8's clutch, but I don't believe I'm seeing that.
Krankor
05 Shinka 6MT
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
