letting more air in
Old Sep 1, 2005 | 11:14 AM
storemannormin's Avatar
letting more air in
I removed my front bumper and notice a big piece of plastic that covers the front of where the air seams to enter your intake. Has anybody removed this? There is also a long 2" tube that goes there as well. I'm thinking of removing both of these and let the air flow directly to my intake...Would this be a good Idea.
Old Sep 1, 2005 | 12:10 PM
galleychief's Avatar
Unbalanced & Unmedicated
I believe what you are referring to is the front end support (black plastic piece)
and the VFAD (long tube). Removing the support only serves to weaken the stability of the body panel. Removing the VFAD will cause problems with air flow into the stock box, will likely cause a CEL, and not help performance.
Just my 2 cents. It's likely others with more technical savy will chime in with additional info.
Old Sep 1, 2005 | 12:17 PM
The bumper support helps keep the bumper from sagging...and doesn't interfere with air flow....the VFAD can be removed with no problems....it is removed when adding the RB air duct...with no CEL or problems. I appears to function mainly as a silencer for the intake
Old Sep 1, 2005 | 01:05 PM
Tigster's Avatar
RX8 ADDICTED!!!
If you do remove it you need to cap off the vacuum hose that runs back to the motor. Or just buy a Revi
Old Sep 2, 2005 | 03:11 PM
ok Thanks did not want to remove it if it would cause problems...I will try it with it off to see if I notice a difference.
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
