Gas cap holder Service Bulletin?
Old Aug 8, 2005 | 05:37 PM
Flop's Avatar
Spinning round and round
Question Gas cap holder Service Bulletin?
Yeah, I can guess that this discussion has come up before.
I did search and people say that if you 'put the thingie on the little notchy thingie a certain way it holds the cap there'. This doesn't work well for me and has caused the cap to go dangling hanging up against the car on numerous occasions.
Is there a service bulletin or a 'fix' that the dealers have for this car? I know for my RSX they changed or added a 'piece' for the cap to stick to. This only happened if the driver brought in the car and complained.
Thanks for the assistance.
Old Aug 8, 2005 | 05:57 PM
expo1's Avatar
He's as bad as Can
No TSB on this and I have not seen many posts about it. Spend $1.00 and do what I did. Even with the note the people pumping the gas ( New Jersey doesn't have self serve) only use the hook 70% of the time. You can't win them all
Old Aug 8, 2005 | 06:21 PM
jskup1's Avatar
The Chief
I just cut the cord off and set it on top of the pump whenever I get gas. I really don't have a problem with remembering to put it back on.
Old Aug 8, 2005 | 06:46 PM
mjcampb's Avatar
Ok, here's what I do. It's real simple, just rember to line either end of the cap ridge to the tab and swing down and forward until it clicks. Try it, it works.
Old Aug 9, 2005 | 02:49 PM
truemagellen's Avatar
Attracts tree branches
I just put the 'string' around the black rubber coated metal piece on the right side...works great!
TSB...come on!
Old Aug 9, 2005 | 05:16 PM
beachdog's Avatar
very cute
Old Aug 9, 2005 | 05:43 PM
zoom44's Avatar
if you get back in your car while fueling make sure to ground yourself on the way out. dont want to hear you caught on fire
Old Aug 10, 2005 | 01:56 PM
QBallz's Avatar
AH HA you learn something new everyday. I've always just gently let it rest up against the fender. It is only plastic after all.
Old Aug 10, 2005 | 02:37 PM
Glyphon's Avatar
脾臓が痛みました
i sandwich it inbetween the pump handle and the body of the car inside the fuel door so that if anything does happen, it will be nicely concealed once the fuel door is closed.
although i do wedge it in the "trigger" for pumps that don't have the clips to keep pumping the gas without my physically being there. that way i can still check the oil and air pressure.
Old Aug 13, 2005 | 02:41 PM
Flop's Avatar
Thank you mjcampb, I'll try this next time I fill up!
theblinkof
Oct 4, 2023 05:24 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
JCTaylor
Sep 30, 2015 07:31 PM
Zube6115
Sep 30, 2015 12:57 PM
Jb4ker96
Sep 27, 2015 10:06 PM
