Loss of power past ~6500 rpm??!!
Old Jul 31, 2005 | 03:31 PM
RX8rider's Avatar
About 3 wks ago, I got a CEL. Took it in to the dealership and had it re-flashed with I'm assuming the new R flash. Car was running normally until today. It seems like once I go past about 6500 rpm in any gear, the speed is just increasing at a snails pace. Whereas this use to be where I felt the greatest pull, now it just seems to be crawling forward. I noticed it when I was cruising at about 75-80 in 6th, dropped it into 3rd (rev matched of course), and I seemed to be holding 75 mph for ever. Got to a straightway and tried to redline each gear (through 4th) same thing happened. Any ideas???
Old Jul 31, 2005 | 04:09 PM
invasion08's Avatar
it could be a clogged cat converter. Next time you are driving and it happens go right to the dealer and have a service manager road test it with you in the car.
Old Jul 31, 2005 | 04:14 PM
Zaim's Avatar
Zaim
I had exactly the same problem and it turned out to be the cat converter. The core has collapsed. It had to be changed..
Old Jul 31, 2005 | 04:16 PM
RX8rider's Avatar
Was that covered under the warranty? Also, what do you think might have triggered it?
Old Jul 31, 2005 | 04:38 PM
zoom44's Avatar
clogged cat. cat failure due to previous flood or over temp because of ultra rich conditions.
Old Jul 31, 2005 | 07:00 PM
RX8rider's Avatar
Thanks a lot guys for your help. I'll be seeing the dealership tomorrow.
Old Aug 1, 2005 | 11:03 AM
Xyntax's Avatar
THREAD KILLER
Have them check your spark plugs. I had the same problem fixed with hot plugs. Dealership said one of my plugs was fouled and the others almost were.
Old Aug 1, 2005 | 12:38 PM
zoom44's Avatar
hes rigth - plugs should be checked as well
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
Espo
Aug 11, 2015 07:11 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
