ABS, TCS and Airbag lights on after hard turn.
Old Jul 29, 2005 | 12:21 PM
joseh's Avatar
Question ABS, TCS and Airbag lights on after hard turn.
I have recently had my RX8 ECU flashed after going to the dealer for a CEL. Since then, I have had the same issue happen to me 4 or 5 times. My morning drive includes getting onto the expressway via a 270 degree loop. On occasion, I get the opportunity to get on with no cars in front of me, and, let’s just say I take advantage of this :D . I love the way this car handles.
However, since the ECU flash, taking this turn at higher speeds causes the ABS, TCS and Airbag lights to come on. They do not turn off until I cycle the ignition.
Has anyone else experienced anything like this? Can this mean that some sensor has detected excessive lateral force and some issue with the ECU flash is shutting these systems off?
If this problem continues, I guess I will have to take the car back to the dealer to see if they can diagnose the problem.
Old Jul 29, 2005 | 12:56 PM
zoom44's Avatar
https://www.rx8club.com/showthread.p...hts#post958149
https://www.rx8club.com/showthread.p...ghlight=lights
not beaing a search nag just pointing youto threads that might help. 270 loop is mentioned inthe second one. try the eps stearing thing "turn all the way tot he left and then allthe way to the right and then back to center" to see if that makes the ligths turn off.
Old Jul 29, 2005 | 01:14 PM
joseh's Avatar
Thanks. I tried doing a search but did not yeild any relevant results. I'll jump onto one of those threads.
Old Jul 29, 2005 | 01:19 PM
zoom44's Avatar
yeah it was hard i ened up just searching threads with lights in the title and scrolling a lot
Old Jul 31, 2005 | 11:00 AM
mmats69's Avatar
93.5 octane
I had the same problem and it boiled down to the ABS speed sensor on the wheel. You may not have heard or noticed but the tires may have been sliding very slightly and this will cause an ABS error.
Old Jul 31, 2005 | 11:32 AM
Sigma's Avatar
Check the ABS sensors. Good chance that one just came unplugged.
RevMeHarder
Jun 1, 2026 02:30 PM
Azki23
Jun 27, 2018 03:48 PM
DVerdeyen
Sep 13, 2015 11:19 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
stickmantijuana
Sep 4, 2015 10:31 PM
