Will Phone wire work for audio?
Old Jun 17, 2005 | 07:07 PM
Unser's Avatar
Question Will Phone wire work for audio?
Question: Can use a 1 foot lenght of phone wire (4 conductor) for +, Ground, audio Left + and Right+ to connect the receiver to the wiring leading to the HU? I just installed Sirius with the Sat reciever above the dash and the plugs/wires are bulky and unsightly ! Help appreciated guys
Old Jun 17, 2005 | 07:32 PM
Way Too Small.............
Old Jun 17, 2005 | 11:09 PM
Unser's Avatar
I meant 1 foot length visible above the dashboard, the rest of the wire until the HU is shielded and audio quality.
Old Jun 17, 2005 | 11:33 PM
zoomzoom_8's Avatar
If you have the homelink rearview mirror, look at how mazda did the wire hide. A hollow piece of plastic. now go to the hardware store, wal-mart, wherever and look for something similar. A black round hollow piece of plastic just a tad large than a straw. use that to hide the wires. Won't look as good as no wires, but pretty close.
Old Jun 18, 2005 | 01:26 PM
Sputnik's Avatar
This kind of feed doesn't require thick cable, but it's not the best idea to use phone cable.
I would suggest finding some black rca pre-amp cables that aren't too bulky for you, and cut the plugs off of the ends.
---jps
Old Jun 19, 2005 | 04:03 PM
Unser's Avatar
Thanks guys, now I've got something to work on, off to the stores.......
Old Jun 19, 2005 | 05:24 PM
StealthTL's Avatar
Metatron
Go down.....
Why not go straight down thru the 'top-dash-piece'?
I asssume you mounted (screwed) the Sat down into the curved plastic top?
Pull everything out a bit, and lift that top piece, then go right down thru it....
S
ei8ht
Aug 21, 2017 09:08 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
cschoeps
Aug 6, 2015 12:44 PM
