throttle body spacer??
Old May 26, 2005 | 01:38 PM
Spyder_doo's Avatar
Turbo'd 5
Lightbulb throttle body spacer??
I found this while searching the ebay listings and wondered if this was worth a try? I have no idea what it does to increase power in the 8 or even where it would go. We have a spacer on our F-150, but again I'm not sure it'll help the 8 out any. Anyone have a coment or thought about this item?
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Old May 26, 2005 | 01:50 PM
Im_DANomite's Avatar
I love GOOOLD
the spacer is designed with these helical teeth that basically produces turbulence in the air. helping it to mix the fuel/air for a better burn. hence, you get more power. and supposedly, with the added length to the intake manifold you get more torque (longer thinner runners make torque, and shorter fatter runners are for high end power) i really don't see it making a drastic improvement. it probably works about the same as that stupid fan thing you stick inside of your intake pipe. what was it called? vortex??
Old May 26, 2005 | 01:55 PM
smrx8's Avatar
looks interesting
Old May 26, 2005 | 02:22 PM
Blue87Sport's Avatar
Rotary only since 1980
Mazda has very carefully designed the intake system on 8 to take advantage of the Helmholtz tuning effect where the lengths of the intake paths are critical to the effect. Messing with the lengths of the intake path is a bad idea unless you really know that you're doing.
Old May 26, 2005 | 03:41 PM
Spyder_doo's Avatar
Turbo'd 5
That's what I was thinking about the lenght of the intake path. I'm not really sure I want to mess with something that is as complicated as the 6 port intake on these cars. But you never know it might produce some good numbers. Only one way to find out, since it's only what $90 I'll probaly get it and see if I cant tell a difference. I dont think it'll work all that great with out tuning it somehow though. Oh well, I'll need to know where it goes first off. Anyone help me out on this? I picture would be nice.
Thanks,
Jamie
Old May 26, 2005 | 03:47 PM
Spyder_doo's Avatar
Turbo'd 5
I think it has to be better than the tornado or whatever it's being called these days. That thing worked pretty good on my '79 MGB. But only difference was MPG and that's bc it's got twin SU carbs on it.
Old May 29, 2005 | 01:36 PM
Won't it will replace the exsisting spacer? Or is it in addtion?
I bet you will feel some gain.
Old Jun 14, 2005 | 03:05 AM
Neipas09's Avatar
Walter OwnZ You!
so did u ever get it?
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
D13
Oct 1, 2015 07:55 AM
Jb4ker96
Sep 27, 2015 10:06 PM
