remote power for amp
Old May 24, 2005 | 11:15 AM
BomberNYC's Avatar
Where did you guys run the remote power from to turn your aftermarket amps on? Also, is there a line output converter that also has a remote power on for amps? i could have sworn i saw this awhile ago where LOC also has a remote power on. Thanks for the help!
Old May 24, 2005 | 04:59 PM
mospeed's Avatar
I wired my remote amp wire to the radio fuse.
Old May 24, 2005 | 10:31 PM
truemagellen's Avatar
Attracts tree branches
depends on the gauge you want to use for running power
I ran 4 gauge in tandem to have a clean direct Power and Ground closed loop to battery...
no good way to do it but drill right through the firewall behind the windowwasher fluid container
I have some pics if you want
it will be much easier to run 6/8 gauge but I thought I'll go all out since I may do a serious sub setup and the video setup is only drawing 9amps MAX at the moment
Old May 25, 2005 | 08:24 AM
BomberNYC's Avatar
i was reffering to the usually blue wire that tells the amp to turn on or off, not the actual wire thats supplying the amp with power. but if you have pics of where you ran your 4 gauge thru the firewall.. i'm interested in that too =)
Old May 25, 2005 | 09:00 AM
RWagz's Avatar
Piston-free 07.11.2007
If you want to be thorough, wire a seperate power line from the battery relayed to the radio fuse. Be sure to seperately fuse it also.
As far as running power cable, I'm fairly sure I'm going to have to run underbody conduits for my power/ground - it's a pain to drill holes in the firewall and run 0/1 under trim panels.
Old May 25, 2005 | 11:35 AM
velocityredRX-8's Avatar
I wired my remote wire to the secondary 12v accessory plug that is located in the center console. I can't remember, but I think that the wire is green and you splice into that.
Old May 25, 2005 | 11:02 PM
I'll explain all these pics later :D
Attached Thumbnails remote power for amp-p1000054.jpg   remote power for amp-p1000058.jpg   remote power for amp-p1000063.jpg   remote power for amp-p1000051.jpg   remote power for amp-p1000061.jpg
juicemantwon
Sep 26, 2015 12:30 PM
gt4uk
Sep 20, 2015 07:19 PM
gt4uk
Sep 20, 2015 11:41 AM
just1jack
Sep 9, 2015 04:45 PM
