So they tell me I need a new clutch...
Old May 23, 2005 | 09:49 AM
Hercules's Avatar
I bought the car in because my clutch pedal was hard to push down. The car pulled fine, it didn't slip, nothing like that, and now this guy is telling me I need a new clutch, and it will be $1100 installed. I told him that I want to take a look at the clutch, but to be quite honest I have no idea what the hell to look for, nor do I have $1100 to give him right now out of pocket.
Somebody needs to give me some information on this, because I *KNOW* I didn't abuse the clutch, and since the car wasn't slipping and pulling just fine before I gave it to the dealership, I find it very hard to believe.
Help!
Old May 23, 2005 | 10:14 AM
eclps0's Avatar
Help!
It happened to me to they say my clutch is gone. But it does not slip and it feels fine, i thonk my dealer and your dealer are trying to screw us over for cash
Old May 23, 2005 | 10:17 AM
Hercules's Avatar
So what did you wind up doign? I called my mechanic and he laughed and said "tell them to hit the road, I'll take a look at it"... ******* dealerships **** me off like no end
Old May 23, 2005 | 11:01 AM
BRealistic's Avatar
Have you tried contacting the 800 Mazda service line?
Old May 23, 2005 | 11:04 AM
eclps0's Avatar
yeah another mech said it was worn but it did not to be replaced. I called masda usa complianing that the dealer wont flash my car, or any thing i ask them to do.
Old May 23, 2005 | 11:33 AM
Hercules's Avatar
Well I just talked with their technician at the dealership, and he said the reason the clutch is stiff is because the pressure plate is gone and that's not under warranty. I am irritated as hell, and I'm not sure what my options are. They won't put the car back together without charging me at least $300, so I'm in a tough spot.
Any help is appreciated.
Old May 23, 2005 | 11:37 AM
BRealistic's Avatar
How can the pressure plate "be gone" at 25k miles unless something was wrong to begin with? I say call the mazda 800 number.
Old May 23, 2005 | 11:50 AM
Hercules's Avatar
I called -- they said the entire clutch assembly is only waranteed for 12k miles or 12 months
They want to charge me over $500 just for parts, so if I am going to get the work done, I figure I may as well replace it with better parts. Any recommendations?
Old May 23, 2005 | 12:00 PM
Hercules's Avatar
Originally Posted by abbid
Mine has been replaced under warranty once before. Clutch, and Pressure plate both. This was over 12k miles. Reason: Loose pressure plate/flywheel bolts caused premature wear on the clutch. And now when i take it in for transmission issues, they blame it on ME!
How can I prove that now, if I'm at 25k miles? I think I'm pretty screwed
I have been looking at the Racing Beat clutch replacements... I can get all the parts I need for around $350. Are there any Racing Beat resellers out there that sell a bit cheaper?
Old May 23, 2005 | 12:06 PM
BRealistic's Avatar
But even the replacement of "wear items" is covered under warranty if the poarts are defective or were improperly installed. As was just mentioned- I would suggest it the flywheel/pressure plate must have been loose from the factory, which lead to the quick wear.
Old May 23, 2005 | 12:08 PM
Hercules's Avatar
Yea, but since I can't prove any of that... *sigh*
They already ripped the car apart and made the diagnosis, and if I want to have a 'second opinion'... they wil charge me to put it back together, at least $300 for which I can almost buy a new clutch and pressure plate.
I'm really in a bind
Nubo's Avatar
Lubricious
I think it's up to THEM to prove something if they're denying warranty. On the other hand, I've read a lot of clutch/tranny threads so maybe it's worth the cash to get some better (aftermarket) parts in there?
Old May 23, 2005 | 12:10 PM
BRealistic's Avatar
Well, maybe have it towed as is to another place to have a new clutch installed. And have them inspect the original flywheel/pressure/clutch plate for signs of improper installation. It couldn't hurt.
Anyways, good luck.
Old May 23, 2005 | 12:11 PM
Hercules's Avatar
They said they can't do anything because it's past 12 months.. I had my car from day one when it was released -- it's nearly 2 years old now (come July).
Anyways.... I am looking at the Racing Beat clutches and pressure plates. The prices seem to be pretty reasonable, so I may just wind up going that route.
Old May 23, 2005 | 12:18 PM
missinmahseven's Avatar
Glitchy Rotary Madness
Have you read the warranty papers that came with the car? A booklet, actually. Any such exclusion should be spelled out in that booklet. I don't have access to mine at this second, but somehow I think your dealer is trying to weasel out of the repair, and screw you over, at the same time.
Get that booklet and read it, fine print inclusive. Arm yourself with knowledge and patience, then tackle your dealer through whatever means you have open to you. Dont let 'em get away with denying a warranty coverage, especially with tales of 8s with improperly torqued (due to a bum wrench!) flywheel bolts.
Old May 23, 2005 | 12:33 PM
eclps0's Avatar
i have 33,000 miles and my clutch has felt weird since 8000 miles I told my dealer about the feeling and they did nothing. and around 28,000 miles tehy had to rebuild my tranny because some gears were missing teeth. It turns out that the pressure plate was loose or something in that nature.
Old May 23, 2005 | 12:34 PM
Fanman's Avatar
Try www.rx8store.net. The discounts on RB products is not huge, but they have a nice flywheel & clutch (which is ACT I believe). That is a good package. OR go to the RB website & you can get all the clutch parts from them. Sucks what happened. I would probably try to get a 2nd opinion. Sounds like your dealership is trying to screw you. Worse off is that you pay for a tow AND the tranny job.
Old May 23, 2005 | 12:39 PM
Hercules's Avatar
How did they find out the plate was loose? And was it covered under warranty?
Old May 23, 2005 | 01:25 PM
BRealistic's Avatar
The warranty booklet ha a long list of things not covered under warranty. On egroup is conveniently vague and called "maintenance at owner's expense", and includes :worn brake and clutch linings" but doesn't mention rotors or pressure plates. Hmm.
Old May 23, 2005 | 01:35 PM
Brice-RX8's Avatar
My understanding is that the clutch material itself is only warrantied for 12/12k but the pressure plate, flywheel, ect are covered under the 50k warranty because they are not parts that are normally worn like brakes and clutches themselves. If the pressure plate is in fact the problem I would get a written document saying that and that they will not cover it and take that up the chain as them deyning a warranted part.
Old May 23, 2005 | 01:38 PM
My last clutch on my MX-6 lasted 100,000 miles. I drive hard but don't abuse it. If the clutch fails on my RX-8 at 25,000 miles they will have to deal with a VERY irrate owner.
Old May 24, 2005 | 12:21 AM
RB clutch and plate are good.
Find the extra money and get the flywheel, you won't regret it.
But the flywheel will void the warrenty.
legine
11
Feb 9, 2026 07:14 PM
Chris Ryan
Jan 30, 2024 01:57 PM
cjkim
Oct 4, 2019 12:24 PM
Euqirne__
May 25, 2015 08:45 PM
MyRx8it
Sep 20, 2012 04:37 PM
