Oils Aint Oils
Old May 22, 2005 | 11:29 PM
Tim Tam's Avatar
Oils Aint Oils
Guys,
I have read things on this list over the past few months about using only "Mazda Rotary Oil", but noticed in the owners manual that they suggest any oil is ok, provided it has the correct rating. There was no mention of mineral based or synthetic. Of course Mazda are going to recommend their Mazda oil, but could it possibly be any better than Mobil 1/Castrol R etc?
Old May 22, 2005 | 11:52 PM
takahashi's Avatar
I don't know if I should say this....
I am preparing Timbo will go off in any minute.
There have been about 20000 posts about engine oil = no real answer.
EDIT: I think as long as it is not corn, sunflower or olive oil, polyunsaturated or saturated. It will be ok. BTW I think Rotary oil is/at least was Castrol made
Old May 22, 2005 | 11:57 PM
Tim Tam's Avatar
I guess Kalli has a point. If Mazda oil is being used at the service, best to top up with the same. We shouldn't be mixing oils.
Kalli, you are wise beyond your (meager) years!!!
Old May 23, 2005 | 02:22 AM
rotarenvy's Avatar
to throw a spanner in the works
how come two stroke motors use clean burning synthetic oils to stop engine deposits but we use mineral oil for supposedly the same reason?
Old May 23, 2005 | 02:32 AM
Jellybean's Avatar
Like Taka, I'm nervous about Timbo if we continue this oil thing too long but ...
My owner's manual says that the temperature range of 5W-30 oil is from -30 degrees to 40 degrees. On the day I had my last service the temperature here was 42 degrees which seems to me to be stretching the capacity of 5W-30. At the other end of the scale, despite living in Canberra, we never get anywhere near -30.
My manual seems to say that 10W-50, covering a range of -20 to 50 degrees, is a more suitable oil for Australian cars.
Maybe we're the victims of a Euro-US big market bias on the part of Mazda -- "we're making this oil suitable for the cooler climate mass markets, and Australia will just have to put up with it".
Old May 23, 2005 | 05:36 PM
timbo's Avatar
rock-->o<--hard place
My patience is surprising even myself :o...I suggest you all conduct a search on 'oil' in this forum, and report back with succinct conclusions ....
And, even though I am tempted -- very tempted -- to offer supportive comments to Jellybean's analysis re the range covered by the Mazda oil, I shall refrain...
Old May 23, 2005 | 06:59 PM
Tim Tam's Avatar
Timbo, half the historical threads seem to be missing for some reason.
AND
If we can't talk about things we've already talked about, eventually we're going to run out of topics. It'd be a pretty boring list then don't you think? Taka would have to post more of his work pics to "entertain" us................
Old May 23, 2005 | 07:03 PM
Gomez's Avatar
Shifty Bastard.
Tim is right timbo, the search feature is stuffed ATM. I have started a thread about it....
Old May 23, 2005 | 07:23 PM
Revolver's Avatar
Shootin' from the hip
Always good to occasionally repeat important topics IMHO. Some people may not have even been aware of the particular issue - a bit hard to search for something when you aren't aware of it.
Those old timers who are bored rigid by the repetition can just close the thread and move on - a la exercising censorship on the telly with the right thumb on the remote, which is always quicker than whinging about something you don't wish to see.
Old May 23, 2005 | 07:31 PM
Gomez's Avatar
Shifty Bastard.
It works both ways. It is forum etiquette that you search before starting a new thread. Oil is a topic that has been done to death....even limiting your search to the Oz forum will answer most questions (when the search feature is fixed :p )
Old May 23, 2005 | 07:40 PM
Revolver's Avatar
I understand the etiquette point and respect it but let's say something has been a closed topic for some time. Not all of us have read everything ever posted (those who have should have a good hard look at themselves ). If we all did searches and answered our questions that way it would never be raised again and:
1. Those of us who were never aware of the closed topic or thought to look into it would never be any wiser.
2. Those of us who have gained more experience and therefore have something extra to add which may benefit us all may never contribute that knowledge.
I'm not suggesting that the whole topic needs to be re-invented again but if some newbie raises it in all innocence it takes only a few seconds to point them in the right direction, thus guiding us all to a wider appreciation of what has gone on before we joined in.
Old May 23, 2005 | 07:46 PM
Gomez's Avatar
Shifty Bastard.
Since the search feature is dead, I'll put this issue to bed .
We don't use mineral oil for that reason. We use mineral oil because some older synthetics used to damage the "o" rings in earlier Rotary engines. Mazda then placarded their Rotary's with an under-bonnet decal stating only mineral oil was suitable for use in the Rotary.
The Renesis has improved "o" rings that are more durable, however Mazda still recommend the use of a quality mineral oil. Here is a bulletin I got from my Service Manager early last year.
Cheers,
Gomez.
Attached Thumbnails Oils Aint Oils-picture-019.jpg   Oils Aint Oils-picture-020.jpg
Old May 23, 2005 | 07:53 PM
Tim Tam's Avatar
Originally Posted by MissRx8
Or, we can talk about how Kall is now paralyzed her back. Maybe I need to "oil" my back up
Kalli's got *******'S BACK!!!!!!!!!
Old May 23, 2005 | 08:06 PM
Gomez's Avatar
Shifty Bastard.
If Tim can get his mind out of the gutter for a minute :p , I can point him in the direction of two LONNNGGGG threads on Synthetic oil.
https://www.rx8club.com/series-i-tech-garage-22/synthetic-oil-renesis-engine-16430/
https://www.rx8club.com/series-i-tech-garage-22/cumulative-synthetic-oil-discussion-52856/
The second one is even a sticky, no search was required....
Gomez.
Old May 23, 2005 | 08:12 PM
Revolver's Avatar
Okay Gomez you win!! :p :D :D
Old May 23, 2005 | 08:15 PM
Tim Tam's Avatar
Sorry Gomez, I've moved on.
Kalli, what would you wear when being oiled up?
(pardon me if this has already been covered in a previous thread)
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
