My clutch is getting to be rock hard...
Old May 18, 2005 | 09:34 AM
Hercules's Avatar
And the dealership just called me up to let me know it 'may not' be covered under warranty. I have never really abused the clutch, no dumping of it, nothing like that... there are 25k miles on it, but a clutch should last longer than that, no?
Let me know what you guys think... I don't want to wind up paying what looks to be >$500 for the fix It should be under warranty if the clutch can't last 25k miles.
Old May 18, 2005 | 09:39 AM
MyRxBad's Avatar
Fb's rock!
Unfortunately a clutch is a wear and tear item. Ask them to let you see it before they change it, and make sure it just wore down normally (if they will let you) otherwise ask for the used part back and inspect it after the fact. If you can prove (if it doesn't get covered) that it was due to manufacturers defect then it'll be covered.
Good luck
Old May 18, 2005 | 09:47 AM
Hercules's Avatar
Good luck
I do have a problem shifting from 2 to 1... not sure if this is any cause of my clutch problems or any symptoms of it.... but I read in another thread that it's a known problem. I just called the dealer and bought it up with them as well, so I guess we'll see what happens.
Old May 18, 2005 | 10:14 AM
MyRxBad's Avatar
Fb's rock!
You can't shift from 2 to 1 at certain speeds, the synchros won't allow it (this is normal)
Unless you match the revs well.
Old May 18, 2005 | 09:40 PM
rxeightr's Avatar
M0D Squad -charter member
Herc,
Took my stock clutch out at 25,000 miles when I changed to a lightweight flywheel. It still had the majority of clutch disc material intact -- very little wear.
I'd guess the stock clutch should last over 75,000 miles based upon how mine looked.
Old May 19, 2005 | 12:40 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Originally Posted by rxeightr
Herc,
That's what I would expect as well... my (autocrossed) Miata's clutch at 75k had over half the material left on it. It would take a tremendous amount of abuse to burn through a clutch in 25k miles.
Old May 19, 2005 | 02:14 AM
Hercules's Avatar
So should this be covered under warranty then? It's been a gradual thing, but I only noticed it when a friend bought his RX-8, and the clutch is MUCH softer than mine... when I went back to drive my car, I felt it to be rock hard in comparison.
The car pulls fine, doesn't grind, nothing seems wrong when I drive it, it's just getting tough to depress, at least as compared to a new RX-8. Any advice would be helpful here, I don't want to pay for these repairs, and my dealership is a bit 'suspect' when it comes to doing fair treatment of customers. I took it there because I assumed it was covered but now who knows
Help!
Old May 19, 2005 | 08:44 AM
MyRxBad's Avatar
Fb's rock!
Are you talking about depressing the clutch pedal? Maybe your shift fork is bent of the clutch cylinder isn't working properly.
Old May 19, 2005 | 10:41 AM
Hercules's Avatar
That's exactly what I'm talking about. It just gets tough to depress, but it seems to operate perfectly fine. Should that be covered under warranty?
Old May 19, 2005 | 10:52 AM
Fab 8's Avatar
Is this related to the squeaking sound that you posted about last week? My clutch is now squeaking at idle and goes away when the clutch is depressed.
Old May 19, 2005 | 01:25 PM
Hercules's Avatar
No, that's something else altogether.... I am just talking about the clutch being hard to press in. It works fine.
Old May 19, 2005 | 04:21 PM
rxeightr's Avatar
The Clutch engages using the Brake Fluid from the Master Cylinder. If your brake fluid level is OK, take it to the dealer for warranty fix.
Let us know what you find out Herc.
Old May 19, 2005 | 05:04 PM
Hercules's Avatar
Will do, thanks for the info
Old May 20, 2005 | 01:08 PM
BRealistic's Avatar
I vote for warranty coverage.
herc- is this your first manual tranny vehicle? just curious. I have drievn them all my life, but have noticed that the RX-8 clutch is very sensitive to slippage by the burnt smell.
Old May 20, 2005 | 01:54 PM
Hercules's Avatar
My first OWNED manual, yea... but I've driven manual for about 4 or 5 years prior so it's not like I am going to be abusing the car by negligence.... I called them up today and they've had my car 3 days now.. the guy on the phone says "The tech thinks you may need a new clutch..." so it seems to me that they still haven't even figured out the problem
I'm irritated at the idea of paying for a new clutch when I don't need one.
Old May 20, 2005 | 02:44 PM
zoom44's Avatar
have you checked you leg, herc?
Old May 20, 2005 | 02:54 PM
BRealistic's Avatar
Yeah. As previously stated I would demand to see the removed clutch disc to inspect for issues. You bought two new 04 Mazda from the same dealership (the RX-8 and Mazda3)? If so, I would talk to the sales rep you deal with, or sales manager, and explain how irritated you are with this situation. You buy two new Mazdas, and not 25k miles later you are told you must pay for a new clutch on a car that hasn't been abused. Explain that you just want the truth- either you abused the car and the clutch problem is your fault, or the clutch or clutch assembly was faulty and will be covered under warranty- either way, they will be able to prove their claim bsed on the removed parts. Also add that you don't want to have to get an outisde certified technician involved.
Anyways- why did you stop posting at C&D? Just curious.
Old May 20, 2005 | 02:55 PM
Hercules's Avatar
Thanks for the info man, I appreciate it. As per C&D... I just read once in a while, don't have the time I used to given my new job and stuff I'm pretty busy lately and I barely have enough time to get online at all, and when I do it's only because I want to frag people in Quake3 or something :D
Old May 20, 2005 | 03:00 PM
Hercules's Avatar
One leg is supposed to be bigger than the other, right? :D
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
