having trouble removing piece aroung the clock...
Old May 16, 2005 | 08:31 PM
projectcar's Avatar
i need to get the peice around the clock off, the one just above the radio/center airconditioner vents...... i plan on getting four gaudes molded/ fiberglassed into the dash, but the shop workers cant get it off, without thinking they are goin to break it...
any suggestions.... should i start from the center console and work my way up?
also... i been reading about a NEO ION....... can someone explain to me what that is please?
Old May 16, 2005 | 08:49 PM
ScudRunner's Avatar
On time, on target
you have to take the stock headunit out in order to access the mounting screws for the center dash console
Old May 16, 2005 | 08:52 PM
StealthTL's Avatar
Metatron
Bottom up.....
You gots to work from the bottom up - it is not possible to just pry it out.
Remove-
shifter **** - unscrew
shifter surround - pull straight up
ash tray - two screws & electrical connectors
stereo unit - two screws (and a hidden bolt!) and pull out a bit
vents - just pull out
finally, top clock moulding, two screws then lift towards rear view mirror.
Have fun :D
S
Old May 16, 2005 | 09:17 PM
forbidden's Avatar
Infernal hidden bolt.......
Old May 16, 2005 | 10:39 PM
adrian-1's Avatar
Ex- member.
I took mine out this weekend to get my gauge pod in.
Here's some pics to help.
Attached Thumbnails having trouble removing piece aroung the clock...-img_1946.jpg   having trouble removing piece aroung the clock...-img_1947.jpg   having trouble removing piece aroung the clock...-img_1949.jpg   having trouble removing piece aroung the clock...-img_1951.jpg   having trouble removing piece aroung the clock...-img_1952.jpg
Old May 16, 2005 | 10:41 PM
adrian-1's Avatar
Ex- member.
Yeah, that hidden bolt is hard to get to. It's 10mm and tricky to get to.
Attached Thumbnails having trouble removing piece aroung the clock...-img_1955.jpg   having trouble removing piece aroung the clock...-img_1957.jpg   having trouble removing piece aroung the clock...-img_1958.jpg   having trouble removing piece aroung the clock...-img_1959.jpg   having trouble removing piece aroung the clock...-img_1960.jpg
Old May 16, 2005 | 10:42 PM
adrian-1's Avatar
Ex- member.
few more
Attached Thumbnails having trouble removing piece aroung the clock...-img_1962.jpg   having trouble removing piece aroung the clock...-img_2057.jpg
Old May 16, 2005 | 11:01 PM
jaehyun127's Avatar
adrian, u just saved my day... i was JUST looking for this... awesome!
Old May 16, 2005 | 11:04 PM
rkostolni's Avatar
What is the single guage pod you have mounted on the Apillar?
Old May 18, 2005 | 02:27 PM
projectcar's Avatar
thankyou
all this info was great.. im not doing it myself.. but went to the garage today and showed them this thread... and they're doing as i type this..
so thankyou
-j
Old May 18, 2005 | 03:55 PM
adrian-1's Avatar
Ex- member.
Defi BF boost gauge w/ warning led for the greddy turbo.
so thankyou
-j
Cool, I'd like to see how your pod turns out.
Old May 18, 2005 | 06:59 PM
BlueRenesis82's Avatar
Registered Tracker
Adrian-1, where did you get your gauge pod from? I've been waiting on the PTP one, but it's been like 6 months and nothing. Any input?
Old May 18, 2005 | 07:47 PM
adrian-1's Avatar
Ex- member.
Check this thread.
Old May 20, 2005 | 08:08 AM
projectcar's Avatar
in process...
it's off, mounted, now waiting for fiberglass to be set.. ill post pictures when complete.. thanks again..
o... could someone tell me what the neo ion is please.. i saw a couple of threads about it and still dont know what it is
Old May 20, 2005 | 08:40 AM
hotpot's Avatar
Neo Ion connects your ipod to your car audio system.
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
SimonT182
Oct 2, 2015 10:33 AM
Quiggs321
Sep 30, 2015 05:34 PM
Learners_Permit
Sep 27, 2015 07:38 PM
