Just great, my battery died.....
Old May 16, 2005 | 07:42 AM
Discman2's Avatar
Rotary Noob
And I have class in 40 minutes.
Question: whats the best type of battery for the rx8?
Old May 16, 2005 | 08:12 AM
JM1FE's Avatar
Optima Red Top G35 R:
http://www.batteriesareus.com/shop/p...products_id=61
You need the height spacer for that one, definitely.
Otherwise, the dealer will probably replace it under warranty with a specific Interstate battery with similar power specs to the Optima.
Old May 16, 2005 | 09:26 AM
Go48's Avatar
The Mazda recommended replacement battery is the Interstate MTP-35 with 640CCA. You may get a dealer to replace the OEM battery under warranty if you squack loud enough. If you buy one, go to an Interstate Battery dealer or you will pay through the nose at a dealer. At Interstate, the battery retails for about $70USD.
Old May 16, 2005 | 04:03 PM
Nubo's Avatar
Lubricious
I went with the Optima Yellow-top (35 series). It has more than enough cranking power, and is designed to withstand deep discharges. That's practically a must these days for any car that isn't always driven frequently, as the electronics draw down the battery if left sitting. Also, it's particularly well-suited to the RX-8, given the possibility of having to go through "deflood" attempts. I want a battery that will survive deep discharge, and maintain voltage further into the discharge.
RevMeHarder
Jun 1, 2026 02:30 PM
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Anthony Kevin
Sep 7, 2015 07:36 PM
iwannarun
Sep 6, 2015 01:37 PM
