Where can I get a PIE adaptor & cable?
Old May 8, 2005 | 01:08 PM
r042wal's Avatar
Where can I get a PIE adaptor & cable? Mazdaparts.com does not seem to work and I really want to get XM radio into my new toy.
TIA
Old May 8, 2005 | 05:27 PM
bt600rr's Avatar
I got mine from mazda parts. It took awhile to get, they might be on back order so you might want to get on the list. I just installed mine and its not working to well though. going in and out. I posted a thread on the issue and hope there is a fix.
Old May 8, 2005 | 07:45 PM
truemagellen's Avatar
Attracts tree branches
not on back order anymore they just got 150 of them in :D it should ship same or next day
Old May 8, 2005 | 08:31 PM
r042wal's Avatar
www.mazdaparts.com is not working. Is that the right URL?
Do you have to have a blank CD in the CD changer in order to use the external inputs on the PIE?
TIA
Old May 8, 2005 | 09:03 PM
no blank cd in the cd player...this is a dedicated aux in
mazdaparts.com is upgrading its server this weekend and is adding products and services for users :D
Old May 12, 2005 | 12:58 PM
ok the products are in the new website:
$114 if you need the upgrade of your Head Unit w/pie & RCAs included (lower than 9.55 need upgrade)...if not then just get these:
PIE:
http://www.mazdaparts.com/ProductDe...0000-1112606399
and RCAs
Old May 15, 2005 | 08:40 AM
StewC625's Avatar
Insanely Yellow
What do you mean by "lower than 9.55"?
Is that a firmware version?
Has anyone seen or used the Neo iPOD controller? This makes your iPod charge and controls it from your head unit ...
http://www.mp3yourcar.com/
Old May 15, 2005 | 10:19 AM
press and hold the 'text' buton and 'preset 1' until a firmware number is displayed...then you will know if it is a 9.50, 9.55, 9.67, etc
it needs to be 9.55 or higher to use and of the plug and play aux in or ipod connection devices (like the neo)
otherwise you need to upgrade the head unit
Old May 15, 2005 | 10:30 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
PIE:
and RCAs
Bad links^
Old May 15, 2005 | 11:01 AM
sorry site was updated i guess here they are
pie: http://www.mazdaparts.com/ProductDet...000-1112606399
rcas 4pie: http://www.mazdaparts.com/ProductDet...000-1112606399
may be gold pricing on these items...but I'm not sure
Old May 15, 2005 | 01:42 PM
StewC625's Avatar
Insanely Yellow
And if my headunit needs upgrading? Where do I go for that?
Old May 15, 2005 | 02:22 PM
TheDosDog's Avatar
Recovered Modaholic
Old May 15, 2005 | 06:09 PM
StewC625's Avatar
Insanely Yellow
Ok, I'm 9.55 ... so I should be apble to use this? I didn't find a DIY for installing it ... is there one?
Old May 15, 2005 | 06:25 PM
9.55 perfect...u can use it for sure
use this for removing the head unit...the just plug into back of head unit (no need to take hu apart after it is out http://www.whatsmyip.org/ipodrx8/
Old May 15, 2005 | 08:37 PM
StewC625's Avatar
Insanely Yellow
What's the skinny on the NEO unit? There seems to be a parallel thread running on that. I like the controllability aspect of it - displaying the tracks etc. on the display. This is just audio-in, correct?
Old May 15, 2005 | 09:03 PM
kachud's Avatar
Mad Scientist
The Neo icelink allows you to control your ipod through the HU. You can change playlists advance and rewind songs ect. The unit is the PIE adapter with the Dension ICElink plus cable. It is exactly the same thing as the Dension unit just repackaged. Yes it is crystal clear audio in but with added features of control
Old May 15, 2005 | 09:06 PM
the neo has been very very problematic...as is the denison icelink
there is a new ipod auxin/controller unit coming out that is problem free...I do not know eta, sorry
Old May 15, 2005 | 09:53 PM
StewC625's Avatar
Insanely Yellow
OK, you're assuming I know what the Denison IceLInk plus cable is ...
Old May 16, 2005 | 01:04 AM
:D pretty much same as the NEo
Old May 16, 2005 | 06:17 AM
rotor's Avatar
sorry i am a bit dumb here ...how do i find out the firmware version ...i know where the "text" button is and wat next? and wat "preset 1" mean?
Old May 16, 2005 | 06:58 AM
kachud's Avatar
Mad Scientist
The NOE buys the PIE adapter. Then they buy the Dension Icelink plus. They put both of them in a box and call it NEO Icelink. I have the NEO system and when it comes it has dension stickers all over it. You also can go the dension homepage to get updates.
The Icelink cable converts the signals of the pie adapter to ipod compatable. which is pluged into your ipod. There is about 40 strings that go into detail. use the search button and you will find all the information you need.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Jelliott5384
Oct 26, 2016 05:15 PM
Danield97
Oct 10, 2015 05:58 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
