Spark Plugs and Wires
Old May 2, 2005 | 06:40 PM
DougK's Avatar
I am new to aftermarket mods and the rotary experience. I was wondering if anybody has bought Ididium spark plugs and if they are worth the cash?
Old May 2, 2005 | 06:47 PM
Stock plugs are iridium...and expensive about $40 each.......
Old May 2, 2005 | 07:01 PM
DougK's Avatar
Thanks.
Old May 2, 2005 | 07:03 PM
army_rx8's Avatar
X-Sapper
only reason to swith is if you are runnign boost (not sure how much till you switch plugs) and you need a colder plug.
someone correct me if i am wrong.
Old May 2, 2005 | 07:36 PM
The plug wires are a good mod. Mine helped smooth out the idle...and I hope they help the weak spark at high RPM's. Guess I won't know till the next dyno...to see if it smoothed out the crap up top
Old May 2, 2005 | 07:43 PM
brillo's Avatar
Go Texas Longhorns!
I replaced my plugs with the new ones and have the RB spark plug wires. I haven't noticed a huge difference in the idle vibration with the wires but the throttle response seems better. My plugs after 12K miles weren't too bad, but I figured that I should got ahead and replace them since I've been through several flashes and the initial breakin.
I need to do a dyno run to see what I'm putting down now.
Old May 2, 2005 | 09:45 PM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
Denso has specific design irdium spark plug (two model, one for normal car, the other for power tuned car) for RX8, It's said it had silicone coating for preventing flooding. I change it with autoexe plug line concurrently. The pedal response is improved, but hard to said any improvement in HP gain.
Old May 3, 2005 | 09:29 AM
guitarjunkie28's Avatar
port hacker
try running bur9eqp's in the trailing ($9 each), and close your leading gap to .028-.032 in the leading (stock plugs) if you're having problems up top.
Old May 3, 2005 | 07:01 PM
twinturbosupra94's Avatar
what is considered high boost 6-8psi...i think i am going to replace them with the denso plugs.....do i need to gap them or do they come pre-gapped perfectly?
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
DVerdeyen
Sep 13, 2015 11:19 AM
iwannarun
Sep 6, 2015 01:37 PM
