PIGGYBACKS & AIR INTAKES
Old Apr 29, 2005 | 05:50 PM
Lock & Load's Avatar
Anyone running a canzoomer or any other type of piggyback system together with the Racing Beat REVI air intake system , ARE THEY WORKING WELL TOGETHER thoughts ??
cheers
michael
Old Apr 29, 2005 | 06:09 PM
army_rx8's Avatar
X-Sapper
please someone post...haha i don't have teh dead presidents for hte turbo...but could possibly get a piggy back....and save up for when the warrenty has gone bye bye. so come on you revi owners...well revi owners with a piggy back.. holaa back youngin' :p haha sorry i couldn't help the last part
Old Apr 29, 2005 | 08:28 PM
Nemesis8's Avatar
Bigus Rotus
I'll let you know as soonn as I get mine back. Having the ignition circuit corrected up North.
I have a great deal of tuning to do. Check out my AFR currently... Pretty frickin rich isn't it?
https://www.rx8club.com/showpost.php...71&postcount=5
Old Apr 30, 2005 | 11:00 PM
WestCoastFun's Avatar
I have the REVi intake and the Racingbeat exhaust... the canzoomer will be installed on May 7th. I will be back home about a week later. I will post my findings then.
Old May 2, 2005 | 09:12 AM
MadDog's Avatar
Consiglieri
I have both the REVi and the CZ. I think they work GREAT together! I have more power than ever. I haven't adjusted my CZ since getting the REVi - since my CanScan broke during my first run with the new intake and is back for repair. But, I haven't noticed and hesitation or anything. I don't anticipate needing to adjust my map.
I am REALLY satisfied with my N/A mods so far. I am planning a cat+pipe soon. I can't think of any more N/A mods, but I am really pleased with my power nowadays. Its sooo much faster than stock!
Old May 2, 2005 | 09:31 AM
Nemesis8's Avatar
Bigus Rotus
I'd like to see your map. My CZ unit should be coming back to me this weekend, so reading your post has me all goofy inside - can't wait to get this critter leaned out a bit. Glad to hear your happy!
Old May 2, 2005 | 11:47 AM
Nem....." I got your ice cream" no whining ...see you Saturday :D
Old May 2, 2005 | 12:38 PM
Nemesis8's Avatar
Bigus Rotus
There is one more mod for us....
Old May 2, 2005 | 12:58 PM
MadDog's Avatar
Consiglieri
and it is.....
-MD
Old May 2, 2005 | 01:45 PM
Nemesis8's Avatar
Bigus Rotus
and it is.....
-MD
One of the most scrutinized topics known to the forum - the preverbal HEADER
Old May 2, 2005 | 04:59 PM
Guys great news thanks for the feed back keep em coming .
cheers
michael
Old May 2, 2005 | 06:28 PM
olddragger's Avatar
header only gave 3 hp and 2 lbs torque for $1200
olddragger
Old May 2, 2005 | 06:31 PM
zoom44's Avatar
that particular header yes.
Old May 2, 2005 | 06:36 PM
Nemesis8's Avatar
Bigus Rotus
olddragger
Headers are half that price now and are producing better numbers. Whoever cracks the siamese center port has the header market wrapped up.
Old May 2, 2005 | 07:15 PM
army_rx8's Avatar
X-Sapper
^indeed they do...lol but no one so far.
only reason i'd get a header is if i plan on getting a supercharger (axial flow) rather than a turbo (greddy) down the road.
haha but by then they might've actualy figured out that pesky center port :D
Old May 4, 2005 | 02:21 PM
teebee's Avatar
Has anyone with the CZ unit had the "N" flash done yet? If so, do you still notice a significant difference with the CZ turned on vs. off?
Old May 4, 2005 | 03:10 PM
Nemesis8's Avatar
Bigus Rotus
Soon as next week for me
I went for the flash, and did not even need an appointment. My mechanic said, "Sure - no problem" But his WDS had a broken pin on the cable end that one of the other mechanics broke. So, the new WDS will be here on Thursday, and I will go back. Then Dan is giving me back my CZ this weekend, so by next week I will be on N and CZ at the same time....
Old May 4, 2005 | 05:22 PM
r0tor's Avatar
Can you check out what your Long Term Fuel Trim is after driving around with the REVi installed... i'm very curious if everyone is experiencing great gains with the REVi because it temporarily leans the car out until the computer adjusts
Old May 4, 2005 | 05:31 PM
Nemesis8's Avatar
Bigus Rotus
Before the REVi was installed, I was at 2% LTFT. But I also reset the PCM allot with my battery mod. I'll get a reading tonight with the REVi installed and post it up also.
Old May 4, 2005 | 05:33 PM
r0tor's Avatar
thank you good sir
Old May 4, 2005 | 05:34 PM
RPIRX-8's Avatar
Apexing at Oak Tree
I'm running REVi, CZ 1.1, and B&B Exhaust. They do work well together. I can't say i'm noticing the gains that others are from the REVi becuase I had a properly tuned CZ before the REVi. Before REVi, I was running about 27% more airflow above 6000rpm. With REVi that number has dropped to about 13%. Sooo, if you were not running CZ before REVi and are now running REVi, I can see how the increased airflow would be felt. Quite honestly, I believe the CZ is the most HP/$ if you want to spend the time to tune properly (which really isn't that hard guys).
Old May 4, 2005 | 05:46 PM
MadDog's Avatar
Consiglieri
What exactly does the LTFT represent? I'm not familiar with it....
I can't wait for my CanScan to be fixed! I'm just running a "safe" map unitl then because it broke before I installed the REVi.
-MD
Old May 4, 2005 | 05:48 PM
MadDog's Avatar
Consiglieri
Are you saying that you adjusted your map down 14% after installing the REVi? If so, can you tell us how long it was after you installed the REVi that you tuned it? Have you logged any runs since then to see if things have changed as the ECU learns the new intake?
-MD
Old May 4, 2005 | 06:12 PM
r0tor's Avatar
-MD
to make a long story short, the LTFT is basically what the computer uses to "learn" new fuel trims. If it consistantly seeing an error in closed loop mode with the factory map and having to adjust, it will eventually move the LTFT to compensate.
Old May 4, 2005 | 07:27 PM
Nemesis8's Avatar
Bigus Rotus
-MD
"Fuel trim in the positive side indicates the computer is adding fuel and, of course, the negative side indicates computer is subtracting fuel. Most manuals suggest that the actual numbers are a percentage figure. That is, a fuel trim parameter of +5 indicates that the computer has added 5% to the base pulse width. I know of no way to prove whether this is correct or not, but it isn't really important. What we need to know is that long-term fuel trim numbers larger than + or - 10 indicate that there's some kind of a problem with base pulse width calculations."
Motor Service - July 2001
