Basslink tuning!
Old Apr 27, 2005 | 06:03 PM
RX8-4me's Avatar
San Antonio TX
Smile Basslink tuning!
For those that have installed a Basslink in the RX8 with the Bose sound system, what settings have you found good?
I have mine installed in the rear corner, like most I think. I'm having a hard time finding setup for bass boost, x-over, etc that i like, so I'm hoping to hear of other's settings.
Thanks for your responses in advance
Old Apr 27, 2005 | 06:40 PM
keyek's Avatar
'73 RX3->'77Cosmo->'79RX7
I have the gain set about 3:30 (with 5:00PM the maximum); the crossover is at 50hz; the bass boost is just past the white dot; my system is set at +6 treble, and -1, 0, or +1 bass; the fade is set at F2; the autopilot is set "on". If you need to fine tune, the bass boost can be adjusted a little at a time with you checking it out with the radio cranked, doors and trunk closed and you in the driver's seat. The fade adjustment from R1 to F3 actually fine tunes the bass depending on your music. Hope this helps!
tbiggybig
35
Jul 14, 2022 06:14 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Danield97
Sep 30, 2015 05:59 PM
