GReddy E-Manage Decision
Old Apr 25, 2005 | 12:16 PM
Cynic10508's Avatar
I've decided that a piggyback ECU should be my next upgrade. The choice as I see it is between GReddy and Canzoomer (which also contains the E-Manage). In order to decide I have some specific questions that I haven't found answers to:
1) How has the E-Manage install changed since MazdaManiac's install before the Canzoomer days? (i.e. Is splicing into the wiring harness still a necessity even with the newer GReddy pieces.)
2) With E-Mange is frying the ignition coils still a concern, and if so are they ways to fix it DIY with parts, soldering gun, and patience?
3) If I were to take this link: http://www.greddy.com/prod_e_manage.htm to a shop what items exactly would I need to tell them to order?
I plan on spending my own time tuning this so Canzoomer's preloaded map doesn't give that much incentive beyond a starting point. Also, I still plan on buying Maurice's CanScan so I can pull data off the CAN/OBDII connection.
Old Apr 25, 2005 | 06:15 PM
blown105's Avatar
I too am considering the emanage unit...
Has anyone installed this emanage unit in the rx8. Any and all help appreciated. Thanks.. Greg
Old Apr 27, 2005 | 11:24 AM
Cynic10508's Avatar
Ok. So this isn't exactly picking up pointers quick. Here's what my guess would be parts-wise for a new E-Manage install (http://www.greddy.com/prod_e_manage.htm):
E-MANAGE (basic unit) piggy-back engine management unit
E-MANAGE INJECTOR HARNESS for main and sub. inj. control
E-MANAGE IGNITION HARNESS for ignition timing control
RPM SIGNAL ADAPTOR 3 RX8 ADPT.
E-MANAGE SUPPORT TOOL CD w/ spl. serial to USB cable
Am I missing anything from GReddy? And should I still get out the wire cutters and soldering gun?
Old Apr 28, 2005 | 12:32 AM
adrian-1's Avatar
Ex- member.
1) There's a RX8 piggyback harness available here (bottom of page). You do all the splicing to that and not your factory wires. Pricey, but better than soldering or splicing your stock wires.
2) I've had the Greddy turbo for a couple of months now and have had no problems with the emanage frying the coils.
Most people here have the emanage as the engine management for the greddy turbo. I know MazdaManiac did use it to tune his stock engine, but even he's custom turbo'd now.
3) Your previous list looks good.
One more note, there's been reports of a new emanage (gold or silver) coming out this summer. What the differences/ upgrades are to the current blue emanage, I do not know.
Old Apr 28, 2005 | 01:22 AM
Cynic10508's Avatar
That link is pretty handy. Although the $198.00 price tag for the harness is kind of steep compared to the $80 for GReddy's two harnesses. I don't know if GReddy's could be spliced into something comparable.
Old Apr 28, 2005 | 04:26 PM
MazdaManiac's Avatar
It hasn't changed much. Greddy now offers a box that performs the RPM signal extraction.
It is still an issue. I have posted everything you need to fix it.
Buy your stuff here:
http://www.mohdparts.com/emanage/
He has good parts and availability. More importantly, he is a good guy, an active supporter of the E-Manage community and will take care of you with regards to service and support.
The various Canzoomer MAPs and their variations are available to download on this forum. Should you decide to install the E-Manage, you can use one of these MAPs (or one of mine) as a starting point.
Search button is your friend.
You would still need the ignition harness from Greddy. You can use the extra wires from that to wire in the injector control in the future should you go with some form of forced induction.
This "patch" harness is a nice thing, but I agree that $200 is a bit steep just to save yourself an hour or two of work.
Old Apr 28, 2005 | 05:16 PM
Lock & Load's Avatar
Jeff
Please check your PM's i have a paying proposition for you .
cheers
michael
Old Apr 28, 2005 | 05:26 PM
r0tor's Avatar
Correct me if I'm wrong, but I wasn't aware that Greddy was tuning ignition timing in their turbo kit (without using the ignition harnass there is no way to fry your coils)
Old Apr 28, 2005 | 05:29 PM
Nemesis8's Avatar
Bigus Rotus
If you are staying NA, why go to all the trouble of the Greddy install? Just get a CZ unit and tweak the fuel and timing and be done with it.
Old Apr 28, 2005 | 06:17 PM
That is correct. The Greddy turbo kit does not include ignition timing control and, therefore, is not prone to coil damage.
Old Apr 29, 2005 | 08:57 AM
Charles R. Hill's Avatar
Owner of BHR
With MM's latest info there seems to be a distinct line drawn between two areas. The line drawn is the matter of ignition timing control and h.p. adders with/without it. I guess with my nitrous project and with MM's turbo kit we have pretty much proven that the RX-8 can tolerate about 55-60 additional h.p. before timing becomes an issue.
As more and more people delve into h.p. add-ons greater than 55-60 we will gain more insight into what all is needed to accomodate these higher levels of boost. It will be nice when we in the RX-8 community have a template from which we can pre-plan our base maps with some degree of accuracy so we know what kind of ignition curve works best with certain levels of manifold boost or nitrous boost.
All this almost makes me want to apologize for having to put the power-adder portion of my mods on hold and, instead, get to structural/drivetrain mods.
MM, you help make more power and I'll show everyone how to contain it.
CRH
Old Apr 29, 2005 | 09:13 AM
If you use the E-manage or CZ to drop the A/F values by adjusting the MAF output...the PCM responds by adjusting the timing a bit. This results in needing to add about 4 deg of advance above 7000 rpm just to stay at the max stock advance of 30 deg at WOT. This would be an advantage to you NOs guys, as a bit of advance spraying would be a good thing. The only problem is you don't really want the leaning either..........If you lean it out...and then add back a bit more spraying it might work well.
Old Apr 29, 2005 | 12:36 PM
Owner of BHR
What is meant by "advance spraying"? The only reason I want to use the E-Man is to reduce the ignition advance enough to prevent detonation with the particular h.p. boost I would like to use. If I am somehow able to also tweak the factory maps for better overall performance then that would be a bonus. From what I am able to deduce so far, once I go WOT the open-loop mode is activated and the E-Man can consistently alter the map successfully. If that is not the case, then I will wait a little further until someone figures out what to do. Until then, I'll move on to the mechanical stuff.
CRH
Old Apr 29, 2005 | 12:48 PM
Cynic10508's Avatar
Hmm. Now I'm debating the merits of purchasing the ignition harness right off the bat. Seems like N/A gains from ignition timing are minimal. Someday in the future I'll go F/I so perhaps investing in that harness now and properly splicing in the coil conditioning circuit wouldn't be a bad idea either.
Old Apr 29, 2005 | 01:10 PM
r0tor's Avatar
CRH
From what I can tell you can change the timing effectively in open and closed loop control as I was able to make my car shake at idle like it had a huge cam'd V8 in it (only as an experiment). For the fuel maps, as long as you stay above about 5500rpms they seem to stay pretty effective (I've had no change in 9 months now)
Old Nov 4, 2005 | 11:57 AM
Petrus's Avatar
v e i l o c i t y
Thread hijack!
Is it possible to connect the e-manage to the usb-port on my laptop? cause I seem to have misplaced the cable that came with it....
And also,,, Last time I started the e-manage support tool I got a question about upgrading. Is this safe or would it damage or ruin something in the e-manage?
Old Nov 4, 2005 | 01:36 PM
Originally Posted by Petrus
Thread hijack!
No. It is not a regular USB port.
Should be fine. Some people have reported that the MAPs were erased when updating, but that is not common. However, you will not be able to update without the proper cable.
Old Nov 4, 2005 | 02:32 PM
Petrus's Avatar
v e i l o c i t y
FU**! Anywhere I can buy just the cable if I cant find it again...?
I don´t want to spend more money...
Sorry to ask, but has anyone tried hooking up the e-manage usb->usb?
Old Apr 12, 2007 | 01:02 PM
hellangel's Avatar
hi, can anyone tell me where to download emanage maps?? maybe i can trade with some of u guys to see which is a better map for my car??
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
jDt!
Oct 2, 2015 04:04 PM
mitchrx8
Sep 13, 2015 08:05 AM
