Oil Pan Capacity
Old Apr 25, 2005 | 10:34 AM
jalibrandi's Avatar
Oil Pan Capacity
I like to do my own oil changes. Changed the oil for the first time and found it took over 4 quarts to get up to the full line on the dipstick. The manual says the capacity is 3.7 quarts. Anyone else with an oil capacity experience?
Old Apr 25, 2005 | 11:25 AM
army_rx8's Avatar
X-Sapper
yea i've changed mine 4 times..and i alwasy put almost 4 quarts in....which is abotu 3.7 Liters.
Old Apr 25, 2005 | 11:27 AM
bluesunlion's Avatar
my other car is blue
Keep in mind that you still have some additional capacity that stays in the oil coolers, etc.
A little under 4 qt for the actual changes sounds about right.
Old Apr 25, 2005 | 11:41 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
If you have a 6speed with dual oil coolers, the system capacity is actually 6.7qts... so how much you get out of it on any given oil change is not a perfect science. I tilt mine a bit with jackstands and can get ~5qts out usually, but about 4qts if I don't. The only important factor is the oil level on the dipstick - just add that last quart slowly until you get it there. After you run it the first time and the filter and lines fill back up, you'll probably have to add a bit more as well.
Old Apr 26, 2005 | 02:26 AM
grinn253's Avatar
Yup, my 6 speed also consumes ~4.75 - 5qts of Royal Purple when tilting the drivers side.
Laters!
Old Apr 26, 2005 | 02:56 AM
juikster's Avatar
Im 8 drifting on a budget
Yup, my 6 speed also consumes ~ 4.75 - 5qts of Crown Royal when twisting my arm too !
Laters !
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Tsurugi
Sep 7, 2015 08:27 PM
