Radio Lights
Old Apr 16, 2005 | 09:37 PM
ridged84's Avatar
Radio Lights
Hey My # 2 & 3 button on the radio dont light up anybody have this problem ? Do you think they can change the bulbs or maybe ill get a new radio?
Old Apr 16, 2005 | 11:36 PM
Z00M RX8's Avatar
The lights are all LED's mounted on a circuit board. They'll have to change the audio panel.
Old Apr 16, 2005 | 11:45 PM
rodmeister's Avatar
Strange, I had the same problem a couple weeks ago. I whacked the panel with the flat of my hand and the lights returned. Hope it stays lit. Just another of the irritating little problems with the RX-8. If she didn't handle so well, I'd be rid of her.
Old Apr 17, 2005 | 01:23 AM
-=Rowdy=-'s Avatar
Same as my last love venture.
Old Apr 17, 2005 | 11:31 AM
Mr M's Avatar
Evolution of REvolution
It is possible the audio is not sitting in its module correctly.
Or that the connectors between the audio and module have been damaged by a technician trying to remove the audio without first removing all the screws (this results in the circuit board being bent/broken. Have you had work done that involves removing the audio?
The only way to check this is to remove the audio panel, remove the audio, and check the connector/circuit board.
Old Apr 18, 2005 | 11:25 AM
Texas 8's Avatar
Integrity First...
I have the EXACT same problem. #'s 2 and 3 do not light. It doesn't happen all the time. Sometimes they'll be out when I turn on the car. Sometimes, they'll flicker a little bit and then go out or flicker and then stay on. Sometimes, they'll just turn off... I can't seem to find any common denominator that would cause it to happen. No big bumps, temp, humidity, etc... I took it to the dealer and of course, they could not duplicate it. I haven't been so bold as to smack it yet. Oh well, something minor I may have to get used to...
nadodave
Aug 28, 2019 05:55 AM
Jelliott5384
Oct 26, 2016 05:15 PM
CARBONRX-8
Oct 5, 2015 03:46 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
