ric shaw ecu?
Old Apr 7, 2005 | 04:33 PM
guitarjunkie28's Avatar
port hacker
ric shaw ecu?
i can't seem to find it online...
anyone know where i can read up about it and/or order one?
thanks
Old Apr 7, 2005 | 04:41 PM
tiggerlee's Avatar
May Cause Anal Leakage
rickshaw: n : a small two-wheeled cart for one passenger; pulled by one person
tiggerlee's Avatar
^sorry I couldn't resist :D
Old Apr 7, 2005 | 04:53 PM
Zaku-8's Avatar
Try also searching for "TSI" . I think it was mentioned on threads here that its the same unit
Old Apr 7, 2005 | 11:57 PM
port hacker
i found it on google, but the link wouldn't work.
Old Apr 8, 2005 | 04:25 AM
Gomez's Avatar
Shifty Bastard.
PM Hymee. I believe he has a contact.
Old Apr 8, 2005 | 09:14 AM
smrx8's Avatar
yeah i believe tsi went out of buisness but i believe ric shaw still has them something like that.
i have one and i might be selling it . i bought it from a friend
Old Apr 8, 2005 | 10:56 AM
port hacker
can you give me any info on it? all i've heard is that it exists, but i don't know any of the particulars.
thanks
Old Apr 8, 2005 | 10:58 AM
smrx8's Avatar
What kind of information u need ???
Old Apr 8, 2005 | 12:52 PM
port hacker
what is it capable of?
and all the general info because i don't know **** about it.
Old Apr 8, 2005 | 01:07 PM
smrx8's Avatar
ok ill be home in a little while ill read through the manual .also i believe hymee has one installed in his car . and you can get a harness so you dont cut into your car ecu wires.
Old Apr 8, 2005 | 03:56 PM
smrx8's Avatar
From reading the manual you can adjust timing,fuel,has nos mode,adjust injecters by one not sure what they mean.if i find anything else i post it up.
Old Apr 8, 2005 | 04:16 PM
Wildcard's Avatar
NT Rotorhead
The ric shaw ECU is more correctly a "TSI" ecu. They have since gone out of business, but Hymee is still in contact with one of the former partners.
Old Apr 8, 2005 | 04:34 PM
smrx8's Avatar
yeah hymee!!!!!! give us the the information i heard you got it installed in your car
Old Apr 12, 2005 | 07:02 AM
Hymee's Avatar
Race Steward
I am in contact with the maker of these units. Ric Shaw does not make them, and the maker told me he only ever sold 3 to Ric.
I am still planning on using this unit with the S/C.
I can't put you into contact with the man himself, as he will only deal with a distrubution network. Which could very well end up being me
Cheers,
Hymee.
Old Apr 12, 2005 | 07:09 AM
smrx8's Avatar
hymee does this unit have a on /off switch i know theres a program that says it for nitrous could you get any more info ????
Old Apr 12, 2005 | 07:48 AM
takahashi's Avatar
So will it later be known as Hymee Enhanced Unit?? :p
It will be great. I want to be able to tune it myself... well to some extent :p
Old Apr 12, 2005 | 03:53 PM
Hymee's Avatar
Race Steward
It does not have an on/off switch per se, but it is a simple matter (10 second job) to bypass the unit by unplugging it and connecting a bypass circuit to the harness.
I'll check up about the Nitrous...
Cheers,
Hymee.
Old Apr 12, 2005 | 03:55 PM
SSR Engineering's Avatar
thanks
We have a stateside source for these units, if you need one we can get you one
Old Apr 13, 2005 | 12:20 AM
port hacker
cool.
i've heard it mentioned, but what are its limitations?
is it just a piggy back that will allow you to add or subtract fuel and timing up to a percent, or can you build a fuel map from scratch?
Old Apr 13, 2005 | 06:39 AM
smrx8's Avatar
Cheers,
Hymee.
thanks hymee , ok so i can wire a switch to inside the car to shut down the ecu
correct ???
Old Apr 13, 2005 | 06:50 AM
Hymee's Avatar
Race Steward
correct ???
No, that would take less than 10 seconds
Unless you rigged up a hi-density switching gang...
What you do is unlpug the harness from the piggy back, and plug a blanking "plug" into the end of the piggy back cable, that hooks into the wiring loom. We made a loom for the RX8 so it plugs in without cutting any wires.
Unles Rad has updated his design for newer models, there is no switch per-se.
I should post some pics.
Cheers,
Hymee.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
vapor2
Jul 9, 2016 07:35 AM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
Draken
Sep 21, 2015 06:14 PM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
