Air/Fuel Ratio meter.
Old Mar 24, 2005 | 01:09 AM
Felix W.'s Avatar
I bought an AFR meter, in expectation of my Greddy purchase.
I know how to splice into the O2 sensor to get the reading, but do I need to use the second, simple O2 sensor, or would it be better to tap the first/wideband one? Is it possible my meter could upset the readings to the ECU ?
Can someone with experience assist?
felix
Old Mar 24, 2005 | 10:41 AM
StealthTL's Avatar
Metatron
Gurus.....
Any tuning 'gurus' here?
Bump
S
Old Mar 24, 2005 | 03:14 PM
you need a bung added to the exaust before the CAT...to which the WBO2 sensor is added.
You can't wire a "meter" to the stock sensors......You Can use a CanScan or ScanAlyser to get the data to a laptop
Old Mar 24, 2005 | 04:18 PM
mospeed's Avatar
why can't you wire the meter to the stock 02 wires? I did with my autometer 02 on my 99 Eclipse GST. Had the meter recalibrated for a tighter range... can't remember the spec Voltage though. i think it was from 10V to 13V. wasn't the most accurate meter in the market but was a nice light show. :-)
Old Mar 24, 2005 | 04:39 PM
MadDog's Avatar
Consiglieri
I don't know if you can splice in another meter or not. But, I do know that if you did, it would need a high input impedance (like a megaOhm). Otherwise, you draw current from the sensor and change the voltage on the line. I deal with this issue on oscilloscopes all the time. You gotta be careful. Adding another device on the line can change the value of the voltage you are trying to read.
Old Mar 24, 2005 | 07:00 PM
bureau13's Avatar
This is true with any air/fuel meter for any type of sensor on any car...they're all designed to tap the signal off the O2 sensor and therefore all have a very high input impedance.
The typical narrow band O2 sensors had a different output range than the wideband sensors...I can't remember but I think the narrowband sensors were 0-1V, and the wideband sensors were maybe 0-5V? However sensors have changed a bit since I paid that much attention to them, so I don't know if this is necessarily true anymore.
jds
Old Mar 24, 2005 | 07:29 PM
WBO2 sensor on the 8..is current based not 0-5V like most meters....therefore won't work :D
Old Mar 24, 2005 | 10:42 PM
bureau13's Avatar
Doh! :D
04Green
Series I Engine Tuning Forum
12
May 13, 2023 10:08 PM
Azki23
Jun 27, 2018 03:48 PM
Vedivan1
Sep 18, 2015 12:39 PM
WranglerFan
Sep 15, 2015 12:09 PM
