problem with 4th gear
Old Mar 8, 2005 | 10:08 AM
crosswound's Avatar
okay i have this problem anytime i launch the car in first gear to 9k rpms and shift through the gears and proceed to 4th i always hear a slight noise like its grinding it goes in just about the same as the other gears i can just hear this noise.
if i wait a bit it won't make it or if i shift real slow and let the rpms drop a lot it won't make it either.
Old Mar 8, 2005 | 10:19 AM
Pkskull77's Avatar
Launching is bad, so if you wanted to avoid further problems stop doing that. Although I am no expert the grind sounds like you Syncros are not keeping up with your shift. Next time you do it, be a little more deliberate with your motions while you shift.
Old Mar 8, 2005 | 10:22 AM
guy321's Avatar
Humpin legs and takin nam
Your 3-4 shift fork may be bent. I had the same problem. When in 3rd, I could not shift into 4th at all over 6K RPM's. It would just grind horribly. Under 6K it would shift every time.
Old Mar 8, 2005 | 10:27 AM
xxdevilzeroxx's Avatar
Revin 9500k
i have that problem now, just take it to the dealer and they will deal with it, either give u a new tranny or replace a gear, what not.....
Old Mar 13, 2005 | 03:49 AM
tpham858's Avatar
I'm glad I didn't buy your car crosswound
Old Mar 13, 2005 | 06:44 AM
crosswound's Avatar
ha turns out it was nothing it was the way i shifted it those few times since it was a lot colder and what not.
Old Mar 15, 2005 | 01:45 AM
Jdunsh's Avatar
JDunsh
I baby my 8, I have only brought it up to 9 once.
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
