Can you identify these components?
Old Feb 12, 2005 | 08:36 AM
Go48's Avatar
Check out the attached photos and see if you can identify the function of these components. There is one of these devices attached to the left front lower A arm (pics 1 & 2), and a similar device (pic 3) is connected to the rear lower suspension component on the same side.
While I was installing new sway bars the other day, I noticed these flimsy-looking gizmos and after a bit of digging in the shop manual, was able to identify their function. See if you can figure it out without looking in the manual.
Attached Thumbnails Can you identify these components?-ui-component-front-bottom.jpg   Can you identify these components?-ui-component-front-top.jpg   Can you identify these components?-ui-component-rear.jpg
Old Feb 12, 2005 | 08:44 AM
StealthTL's Avatar
Metatron
Yes....
So as not to spoil the quest for others,
I will just say -
the reason they are there is not obvious, it's hid.
S
Old Feb 12, 2005 | 10:30 AM
gnj152's Avatar
sensor for weight and head light angle repositionning
Old Feb 12, 2005 | 03:40 PM
robertdot's Avatar
I will just say -
S
HAHA
Old Feb 13, 2005 | 09:22 AM
Go48's Avatar
You got it. Of course, Stealth provided the HIDden clue.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
