TT turbo any one ?
Old Jan 31, 2005 | 06:18 AM
RX8 XTC's Avatar
TT turbo any one ?
woulde the Rx8 handel the twin turbos ? sorry if it was a repost :D
Old Jan 31, 2005 | 08:01 AM
DreRX8's Avatar
It doesn't need twin turbos. Twin turbochargers in an application of this type are not feasible--the added piping and vacuum hoses would create such a mess for the same output as an efficient single turbocharger. Initially, twins were used to minimize lag--but technology has improved since 1993--so the benefits of a twin setup are negated--not to mention the cost associated with such a setup.
Old Jan 31, 2005 | 02:23 PM
rotarygod's Avatar
The twins on the RX-7 were terribly unreliable and overly complex. I can never figure out why people always want twins. I guess if one is good, two must be better?
Old Jan 31, 2005 | 02:32 PM
DreRX8's Avatar
Well back in the day--twins were supposed to minimize turbo lag down low--at least thats what all the technical jargon was from RX7/Supra/300ZX/3000GT brochures in '95 said. Nowadays they are redundant.
Old Jan 31, 2005 | 02:38 PM
dmp's Avatar
dmp
RX8 and a Truk....
...By a vast majority, the "really fast" supra's, and FDs, etc, have all done a 'twin-to-single' turbo conversion.
:D
Old Jan 31, 2005 | 02:53 PM
Ajax's Avatar
That's sequential twins tho, not true twin turbo.
Old Jan 31, 2005 | 03:07 PM
rotarygod's Avatar
There are other ways to get good boost response and good total boost than slapping 2 pigmy sized turbos to an engine and making it overly complex. The stock turbos didn't spin all that freely and they were restrictive. More backpressure before the turbo means more boost that is needed to overcome it. A larger single turbo, a properly designed exhaust manifold and better bearings in the turbo would have given a single turbo that spooled up as fast as the stock twins, was more reliable, and produced less heat. All factors that hurt the reliability of that car. This also would have been cheaper to manufactur as well as service. Never send a child (or 2) to do a man's job. Creative marketing worked good back then. too bad many still believe it. The idea is actually sound in theory. the problem was the execution of it was bad.
Old Feb 1, 2005 | 02:51 AM
RX8 XTC's Avatar
well then looks like a single Turbo is good :D
Old Feb 1, 2005 | 08:28 PM
Overport's Avatar
Overport
the rx8 doesn't need a twinturbo. in an rx8 its really not feasible because the added piping and vacuum hoses would make such a mess for the same out put of a good single-turbo design. twins are mainly used in an effort to minimize turbo-lag, but this is old technology so the benefits are next to zero. then you factor in the extra cost of a twin turbo design. so, in all reality, a single turbo setup is better than a dual, especially on modern cars,
Old Feb 1, 2005 | 09:11 PM
PoorCollegeKid's Avatar
:D
A lot of the really fast Supras also have powerbands that start at 4000rpm (if not later), which isn't exactly conducive to a street driven daily driver. <shrug>
Old Feb 2, 2005 | 12:09 AM
rotarygod's Avatar
That's because they use beer keg sized turbos that are only efficient at high rpm's and boost levels. That has nothing to do with the fact that there is only one of them vs the stock two.
Old Feb 2, 2005 | 04:15 AM
RX8 XTC's Avatar
for some reson i want twin Turbo's Ahh its like TTRx8 :D
Old Feb 2, 2005 | 09:45 PM
Rick's Avatar
Well, I'm very happy with the sequential twins on my FD. It can accelerate quick (or spin the tires ) from low rpm's and still put out a respectable 300+ rwhp at 13 pounds.
Old Feb 3, 2005 | 03:35 AM
Fanman's Avatar
Not to mention nobody is sure that the engine of this car can handle the extra hp that a 2nd turbo would give us. Essentially the current turbo in the Greddy kit is the 18G that Greddy uses on their twin turbo kit for the Nissan 350Z. There is a very large difference in price Nissan 350Z Greddy kit (Retail = $8,190, Street = $5,869) vs. RX8 Greddy kit (Retail $4,195, Street = $2930), not to mention the complexity of the system as stated above. Right now nobody is sure that this engine can even handle one turbo at 9 psi, let alone two. I'm sure with more research, and more installs things will change.
Old Feb 3, 2005 | 04:47 AM
RX8 XTC's Avatar
well i don't know so much about rotary but can you tell me the Exact difference between the FD and this ONE ?? other than the Turbo And NA ?? am assuming nothing much except Improvement or am i Wrong ?
Old Feb 3, 2005 | 07:51 AM
DreRX8's Avatar
The TT setup in the RX7 was fine for daily driven use--but for big horsepower numbers a single is best--the problem is with a single you usually would sacrifice the quick spool up time (i.e. lag) of the sequentials. A single turbo also cleans up the wossness of vacuum hoses that are oh so problematic.
Old Feb 3, 2005 | 10:11 AM
slavearm's Avatar
Boost Junkie
Higher Compression, Different Ports, Different Side SEaling (new design) to support new porting, new oil injection system, returnless fuel system, I could go on, but you should really just read.
Slavearm
Old Feb 3, 2005 | 08:10 PM
guitarjunkie28's Avatar
port hacker
i'd like to see a twin turbo rx8...not for power, but for spoolup since the side exhaust flows like butt stock.
but i'd like to see it setup more like the supras...nice and simple.
Old Feb 3, 2005 | 09:50 PM
Ajax's Avatar
I'd prefer to see mazda's electric assist turbo than twins. The stock ports cant be THAT bad or we wouldnt see any kits at all..
Old Feb 5, 2005 | 08:02 AM
RX8 XTC's Avatar
slavearm
So if they did all this improvment to the engine you still saying that it wont handel a TT like the fd did ??
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
