Did a baseline dyno on my 04 rx8 6spd
Old Jan 27, 2005 | 02:36 PM
gxsilver's Avatar
did a base run today on a dynamic Dyno.........
car did 184.4 hp
not to bad I guess, since I came from a 2003 mustang Gt making 400hp
but this car does get the girls to look !!!
(i had a pretty, young bank teller start flirting with me in the drive thru line---the mustang never got that !!! )
Old Jan 27, 2005 | 02:42 PM
rx8pilot's Avatar
Watch your six
I'll go ahead and say it.. because rest assured..someone will if i don't..
POST PICS OF THE DYNO RUN...............................please
and what gear did you dyno in? conditions? etc..
thanks.
Old Jan 27, 2005 | 02:45 PM
smrx8's Avatar
pretty good i hit 186 with a racing beat exhaust
Old Jan 27, 2005 | 02:46 PM
dmp's Avatar
dmp
RX8 and a Truk....
what is a dynamic dyno?
philodox's Avatar
Rangers Lead The Way!
car did 184.4 hp
nice baseline.. post a pic of the dyno sheet.. it's the only way you can get street credit with this crowd
Just another company that makes dyno's.. like mustang, dynametrics, dynojet, etc..
Old Jan 27, 2005 | 02:47 PM
dmp's Avatar
dmp
RX8 and a Truk....
Philo - I didn't see if you answerd - sorry to topic jump;
Were the dyno numbers from your recent dyno 'correct'? If so, do you know what the correction factor was?
Old Jan 27, 2005 | 02:49 PM
philodox's Avatar
you should always use uncorrected results for a forced induction system. the reason being is with FI you create your own atmospheric conditions from pressurizing the air. make sense?
Old Jan 27, 2005 | 02:51 PM
DreRX8's Avatar
Yeah--the RX8 gets the girls to look ~$ $~
Old Jan 27, 2005 | 04:18 PM
dmp's Avatar
dmp
RX8 and a Truk....
However, humidity, heat, etc, can change things - I think corrected values are still valid, having said that, I always use uncorrected results anyway...to me its more important what my car actually measures at, not what it'd measure in a 'perfect world'.
:D
Old Jan 27, 2005 | 04:29 PM
philodox's Avatar
:D
True, but the thing is, the ambient air temp is not intake temp through the turbo and intercooler nor is the barometric pressure correct since the air is pressurized in the intake system. So the correction value the dyno program comes up with is going to be way off base compared to actual conditions inside the car which you can't really measure without a butt load of special equipment.
For a N/A car, corrected values are useful.. but for forced induction, they are very sketchy.
Old Jan 27, 2005 | 05:01 PM
cretinx's Avatar
Why are these cars dynoing so low? If they've got 238 hp like Mazda claims they should be putting down at least 200 hp stock.
Old Jan 27, 2005 | 05:07 PM
philodox's Avatar
hehe.. that issue has been kicked around in a bunch of threads. just search the forum and you'll probably find 15 or 20 of them
Old Jan 27, 2005 | 05:19 PM
dmp's Avatar
dmp
RX8 and a Truk....
...only when comparing plots between cars in different areas, on dif dynos, etc. :D
Old Jan 27, 2005 | 07:22 PM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
We need pic's of the dyno run, and yes...the whp is around 175-185 range for the RX8 from what I have read.
Old Jan 27, 2005 | 08:29 PM
zoom44's Avatar
why do you think that?
Old Jan 27, 2005 | 09:42 PM
Nemesis8's Avatar
Bigus Rotus
Not bad at all - a high end claim - let's see the sheet man
Original RX8 247HP at the crank (Assume 20% loss = 197 RWHP)
Detunned US RX8 238HP at the crank (Assume 20% loss = 190 RWHP)
RX8Club Member RX8's make 210-220 HP at the crank (Assumine 20% loss = 168-176 RWHP)
Old Jan 27, 2005 | 10:14 PM
Richard Paul's Avatar
Sorry your wrong Jon, corrected numbers are important no mater what. Blown engines are not exempt. We use these corrections so we can compare engines run in differnt conditions. If I run a test in Santa Monica and you run yours in Denver who has more power. I'd beat you hans down every time. You have to get a correction for altitude and temp and water vapor.
We all correct to the same standard. Now standards are different. We have SAE and Standard. All after market people use Std all Oem's use SAE.
The SAE uses ........................I don't remember. but I think it's 29.38 Hg and 70f.
Std is 29.92 and 60f. you can see the diff.
The factors seem to be accepted through out the industry. Except by some men in the RX 8 club.com. Well like I said "Just because it is written does not mean it is carved in stone"
Who knows there might be another Ricardo in our ranks.
Old Jan 27, 2005 | 10:21 PM
dmp's Avatar
dmp
RX8 and a Truk....
Tis why I don't compare my car with any car but those run during my dyno sessions...Thus, I only read 'measured'.
Old Jan 28, 2005 | 01:06 AM
blksf8's Avatar
where's this guys sheet already?
Old Jan 28, 2005 | 01:18 AM
rotarygod's Avatar
I agree with that in terms of belt driven superchargers but not when it comes to exhaust driven turbos. Remember that a turbo will compensate to a point for altitude since it makes boost pressure as a reference to sea level pressure. Since a belt driven supercharger makes boost relative to ambient and not sea level, a correction is needed. Technically there should be some form of correction for an exhaust turbocharged engine too but the standard correction factors are more wrong than they are right. You and Jon are both right. It just depends on what type of supercharging you are using.
Old Jan 28, 2005 | 01:40 AM
MazdaManiac's Avatar
^ Agree.
SAE corrected HP doesn't work for FI engines - turbo even more so.
Old Jan 28, 2005 | 02:00 AM
gxsilver's Avatar
i'll post it very soon, i'm pretty swamped at the moment.......
Old Jan 28, 2005 | 09:26 AM
RX3+5's Avatar
Bullshit Detector
Could you post the raw data as well please?
Vince
Old Jan 28, 2005 | 09:58 AM
leigh44's Avatar
Please help me understand something. Mazda states 238hp. We see rx-8 club members all the time with 210-220 at the crank. Then we "assume" a 20% loss. Why dose this car only put 170-180 to the rear wheels? Don't get me wrong I love my car but crap we jump all over products that claim 5-15hp increases and spend $300.00-$1200.00 for them and we are down 58hp from the claimed crank hp to actual wheel hp. What is the reason for that big of a loss?!?!?!?!
Old Jan 28, 2005 | 10:08 AM
dmp's Avatar
dmp
RX8 and a Truk....
Originally Posted by leigh44
Please help me understand something. Mazda states 238hp. We see rx-8 club members all the time with 210-220 at the crank. Then we "assume" a 20% loss. Why does this car only put 170-180 to the rear wheels? Don't get me wrong I love my car but crap we jump all over products that claim 5-15hp increases and spend $300.00-$1200.00 for them and we are down 58hp from the claimed crank hp to actual wheel hp. What is the reason for that big of a loss?!?!?!?!
Just a correction - I have yet to see ONE rx8club member dyno his engine at the crank. Automakers NEVER rate their cars at 'wheel HP'. We are likely down 10-20HP from what mazda rates...based on our WHEEL HP and guessing what acceptable drive-train losses should be.
