Frozen Clutch---Suggestions
Old Jan 21, 2005 | 02:01 PM
Samyv's Avatar
Question Frozen Clutch---Suggestions
Hey Gang!!
Here is the situation:
I went to start my car this morning, it's -24 below. The car started no problem. However when I took my foot off the clutch it remained engaged. It seemed to be frozen or something. Everytime I took my foot off the clutch the car would role forward and stall. Finally after about 30 minutes it worked fine and I was able to drive away.
Anyone have an ideas why this may have happened or suggestions on how it can be prevented. This has never happened to me before.
Old Jan 21, 2005 | 02:17 PM
PUR NRG's Avatar
Originally Posted by Samyv
However when I took my foot off the clutch it remained engaged. Everytime I took my foot off the clutch the car would role forward and stall.
Can you clarify these two comments because they seem contradictory. Either you released the clutch pedal and the clutch remained disengaged or you released the clutch pedal and the car would roll forward and stall. If it's the latter then it sounds like you didn't rev it enough.
________
Easy vape
Old Jan 21, 2005 | 02:22 PM
vectorwolf's Avatar
Totally confuzzled...
Hmm... Some components, like brake pads and clutch friction material, are semi-metallic and stick BADLY in the cold. Alot of us have run into the sticking e-brake issue on really cold mornings, for example. The material is probably just very, very cold and thus leaving no room for error... Your engine warming up should take care of this problem, though.
Old Jan 21, 2005 | 02:26 PM
Slims8's Avatar
Piston Traitor
Hey Gang!!
Yeah, I gotta suggestion... Move to Tx, it's 75 degrees!
-24? I'd freeze in 5 minutes!
Old Jan 21, 2005 | 11:47 PM
KKMmaniac's Avatar
VW coulda had it...
In neutral? Because of the temperature, the gear oil was probably the consistency of uh... frozen molasses. Anyway, the drag the gears and shafts in the gearbox swimming in this oil imposes upon the engine, combined with the low torque of the engine at low RPM could cause it to stall.
I know at low (but not quite that low) temperatures, my engine will slow down and the car will lurch forward as I let out the clutch pedal in neutral. Is that it maybe?
Uncivilizedracer
Jan 11, 2010 02:23 PM
PSTNLSS
9
Dec 22, 2008 05:16 PM
pdxhak
Oct 23, 2008 01:21 PM
Ned M
Jan 31, 2008 04:42 PM
Nemesis8
RX-8 Multimedia/Photo Gallery
Feb 18, 2005 02:12 AM
