estimated power?
Old May 26, 2003 | 11:31 PM
rotorex's Avatar
estimated power?
just as a rough estimate, how much power and tq do you think a 1.5 liter or 1.6 liter twin rotor RENESIS could produce while NA?
Old May 27, 2003 | 11:34 AM
neit_jnf's Avatar
Well, currently it's doing 192 hp/L and 122 lb ft/L so if you use the same numbers and come up with some factor for the increased friction/inertia/ etc of the bigger engine, then...
192*1.5 = 288
122*1.5 = 183 roughly 280 hp and 180 lb ft ??
192*1.6 = 307
122*1.6 = 195 roughly 300 hp and 192 lb ft??
REMEMBER I'M JUST GUESSING
Old May 27, 2003 | 11:45 AM
Hercules's Avatar
Probably more than that, because the RENESIS in the RX-8 isn't making maximum power.. I believe it was originally tuned to 300 horses when the concept was released, and the engine size was the same.
So probably a bit more than that.
Old May 27, 2003 | 07:36 PM
MikeW's Avatar
1.5 liter (90mm width rotors instead of 80mm) & non conjoined center exhaust ports
275hp
175ft-lbs
100mm wide rotors (1.6)
300hp
190ft-lbs
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
