RX8 wiring manual
Old Jan 4, 2005 | 03:17 AM
aa@uow's Avatar
RX8 wiring manual
Hi, I need the manual for installing alarm.. can anyone help me out? thanks bro!
Old Jan 4, 2005 | 05:03 AM
Go48's Avatar
Rosenthal has one for $54USD. Go here:
http://www.finishlineperformance.com...intenance.html
EDIT: If you know what sections of the manual you need, I can copy them for you. There is also a shop manual available on CD on eBay for a few bucks, but I don't know if it is a good as the hard copy available from Mazda. It does have a wiring diagram, though.
Old Jan 4, 2005 | 09:29 AM
aa@uow's Avatar
Thanks alot Go48!! basically i need the diagram for all those small cables under the steering wheel.. do u think u can send me a copy? that would be very nice! thanks alot bro!
Old Jan 4, 2005 | 09:58 AM
MDRX8's Avatar
I need the wiring at the IAT sensor on the air intake to tell which five wires is IAT
Old Jan 4, 2005 | 09:59 AM
Go48's Avatar
Unfortunately, the wiring diagrams don't work that way. They are all schematics with the individual diagrams associated mainly with particular devices or systems. So there is no diagram for wires in a specific place in the car. I will attach an overall diagram that may or may not be of any use.
Old Jan 4, 2005 | 10:54 AM
aa@uow's Avatar
you've done so much!! thanks alot bro!
Old Jan 4, 2005 | 11:54 AM
Go48's Avatar
OK, save me the task of figuring out what IAT stands for and I will copy the appropriate diagram.
Old Jan 4, 2005 | 12:52 PM
MDRX8's Avatar
Intake Air Temp. part of the sensor on the air intake tube
Old Jan 4, 2005 | 02:19 PM
Go48's Avatar
The wiring diagram does not show the IAT per se, but according to my interpretation of the section on the MAF system, the IAT is a part of that system. So, I have attached the wiring diagram for the MAF and the diagram showing where it connects into the PCM. I have also attached the 2 pages in the shop manual that lead me to believe that the IAT is integrated into the MAF system. Good luck with your project.
Attached Thumbnails RX8 wiring manual-maf-iat_1.jpg   RX8 wiring manual-maf-iat_2.jpg   RX8 wiring manual-maf-iat_3.jpg   RX8 wiring manual-maf-iat_4.jpg
Old Jan 5, 2005 | 10:10 AM
aa@uow's Avatar
Hey Go48, the wiring diagram is realli cool but do u think that u can make it bigger and easier to read? thanks alot bro.
Old Jan 5, 2005 | 10:47 AM
Go48's Avatar
The size of an attachment to a posting in this forum is limited to 200KB. So it will not be possible to send anything through this forum any "larger" than what I sent. If you want a larger image you can copy the image from the forum to your HD and use an image viewing program to enlarge and rotate the image. As an alternative, send me a PM with your e-mail address and I'll send you a higher resolution and/or larger physical size of the image.
Old Jan 5, 2005 | 11:28 AM
MDRX8's Avatar
Old Oct 17, 2012 | 04:34 PM
Bl1nD_RX's Avatar
Str8 Rippin
i dont suppose you have the diagram for the room fuse do you? i keep blowing it after a breakdown and im grasping at straws...
Old Sep 17, 2014 | 05:47 PM
SiNfidelity's Avatar
Is this correct for 6port manual? 2005 model s1
Old Sep 17, 2014 | 05:57 PM
There will be differences in the keyless entry and some of those systems...but the other basic stuff will be basically the same...hope that helps
If you want the .pdf send me a PM
Old Sep 29, 2014 | 08:13 AM
firebirdude's Avatar
User and Abuser
If anybody is reading this and looking to install an alarm/remote start/etc, don't suffer sorting through all these schematics.
2005 Mazda RX-8 DirectWire Vehicle Information
Item Wire Color Polarity Wire Location
12 Volts green (30A) or orange (30A) + driver kick fuse box
Second 12 Volts yellow (x3) (common 15A) + ignition switch, white 6 pin plug, pins E and F
Starter white/blue + ignition switch, white 6 pin plug, pin A
Second Starter N/A
Ignition black/yellow + ignition switch, white 6 pin plug, pin C
Second Ignition N/A
Third Ignition N/A
Accessory blue/green + ignition switch, white 6 pin plug, pin B
Second Accessory white/red + ignition switch, white 6 pin plug, pin D
Third Accessory N/A
Keysense pink/black + ignition key switch, wht 2 pin plug, pin B or KCM, 24 pin plug, pin F
The KCM (Keyless Control Module) is above the passenger kick.
Data Bus blue/orange (TX), yellow/black (RX) data PATS Transceiver around ign key sw, white 4 pin plug, pins B and A
The PATS ignition is black/white in pin D, and ground is black in pin C.
Can Bus High blue/white (HS CAN) data data link connector, black 16 pin plug, pin 6
Can Bus Low green/black (HS CAN) data data link connector, black 16 pin plug, pin 14
Can Bus Sw N/A
Power Lock lt. green -1000 ohms driver kick or KCM, 24 pin plug, pin V
Power Unlock same as power lock -
Lock Motor red/blue 5 wire driver kick or KCM, 6 pin plug (1), pin D
Driver Unlock Motor red/black 5 wire driver kick or KCM, 6 pin plug (1), pin C
Parking Lights (-) lt. green - headlight switch, white 17 pin plug, pin L
Parking Lights (+) black/red + driver kick, harness to rear
Hazards orange - hazard switch or KCM, 24 pin plug, pin I
Turn Signal (Left) green/yellow + turn signal switch, white 17 pin plug, pin A
Turn Signal (Right) black/red + turn signal switch, white 17 pin plug, pin E
Headlight yellow/red - headlight switch, white 17 pin plug, pin J
AutoLights N/A
Reverse Light red/yellow + driver kick, harness to rear
Left Front Door Trigger white/red - driver kick, harness to rear
Right Front Door Trigger black/blue (will also detect driver door) - driver kick or KCM, 24 pin plug, pin K
Left Rear Door Trigger same as right front door trigger
Right Rear Door Trigger same as right front door trigger
Dome Supervision green/black - driver kick or KCM, 6 pin plug (1), pin B
Trunk/Hatch Pin brown - driver kick or KCM, 24 pin plug, pin G
Rear Glass Pin N/A
Hood Pin purple/white - N.C. hood switch or KCM, 24 pin plug, pin D
Trunk/Hatch Release yellow - trunk lid opener switch or KCM, 24 pin plug, pin E
Trunk Release Motor blue + driver kick, harness to rear
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm green/red (driver door key cylinder) -1000 ohms driver kick or KCM, 24 pin plug, pin S
Factory Alarm Disarm same as factory alarm arm -
Disarm No Unlock use keysense
Trunk Alarm Shunt gray/red (trunk key cylinder) - driver kick or KCM, 24 pin plug, pin H
Tachometer lt. green/red or lt. green/black ac PCM, second plug from passenger side, pin M or J
The PCM (Powertrain Control Module) is in the passenger side front corner of the engine compartment.
Wait to Start N/A
Neutral Safety blue/red (M/T) - PCM, second plug from passenger side, pin O
Clutch Pedal lt. green/red + clutch switch, black 2 pin plug, pin B
Fuel Pump white/red + driver kick, harness to rear
Rear Defroster gray - latched A/C Amplifier under dr dash next to cntr console, 24 pin plug, pin K
Mirror Defroster same as rear defroster
Left Front Heated Seat blue + latched left seat warmer switch, black 6 pin plug, pin H
Right Front Heated Seat red + latched right seat warmer switch, white 6 pin plug, pin H
Speed Sense green/red ac radio, 24 pin plug, pin I
Brake Wire black/blue to black/yellow + brake switch or driver kick, harness to rear
Parking Brake gray - parking brake switch or instrument cluster harness
Horn Trigger green/orange - horn switch or KCM, 24 pin plug, pin C
Wipers blue/white (L), red (H), blue (ignition) + wiper switch, white 14 pin plug, pins K, O, and E
Old Oct 1, 2014 | 04:58 AM
zaktravel's Avatar
Hello all, My apologies if this is the wrong thread. I have problem with starting the car as I turn on the ignition key the car boot automatically opened and the alarm sounded with no cracking of the engine. I suspect this could be a wiring issue. I hv just picked my rx8 back for engine replacement to rx7 engine with turbo. Any good pointers are very much appreciated.Tqvm.
Old Oct 3, 2014 | 08:55 AM
User and Abuser
Sounds like you need to take it back to the shop that did the engine swap.
Old Oct 4, 2014 | 03:05 AM
zaktravel's Avatar
Thanks Dude, I would hv thought the same but he is quite a distant away. Was able to drive it home with no problem but u never know bad things happened. Thought I could do a quick fix ��
Old Oct 4, 2014 | 08:20 AM
User and Abuser
No crank, but tripping the alarm MIGHT be a dead/low battery. But I've never heard of a low battery popping the boot.
Also, if you have one, try a different key. It's possible the transponder inside the key went dead. In which case, the car wouldn't start and the alarm would be triggered because it thinks the car is trying to be stolen. Again, haven't heard of this popping the boot.
Old Oct 5, 2014 | 02:58 AM
zaktravel's Avatar
Yep. Tried changed to a new battery.. Same thing.. Boot popped out when tried to crank the engine and the alarm went off. I only had one key! Already contacted the mechanic but he is away in Japan and only be back next tuesday.
Speaking of being stolen, good thing with fB, news spread like wildfire... found my wife's stolen car at the workshop for repair.. Went thro' a lot of hassle and eventually bringing in the cops to take the car away ( Appreciate for yr trying to help.
Old Nov 11, 2014 | 01:21 PM
FateGR's Avatar
Hello guys.
Someone in an attempt to steal or damage my car, cut some cables beneath the steering wheel of my manual RX-8.
the first picture shows the plugs, right next to the brake cable.
the second picture shows the cables that lead to the brakes.
the third picture shows the cables right above the gas pedal that leads to this brown box.
Could someone who knows these things, tell me, which harness I should replace.
Is it the "under dashboard" harness or does it have to do with the engine harness?
Please help a fella out, I am totally dissapointed!
Old Nov 11, 2014 | 01:32 PM
Call your insurance company :-)
Old Nov 11, 2014 | 01:34 PM
FateGR's Avatar
I did it but insurance companies are non-existent and low-quality in Europe.
I wonder if someone knows which harness replaces all those cables.
I would be grateful to him!
Old Nov 11, 2014 | 01:37 PM
That's all on the main harness...the engine harness is all in the engine bay.
It is a huge job to replace the main harness...it requires removing all the interior in the whole car and a lot of the engine bay
