Oil Help
Old Dec 8, 2004 | 06:17 PM
Owens's Avatar
Oil Help
So I checked my oil today and it was a quarter about the minimum line, so I not even a half a quart and went to check the dipstick again and the oil level was now over the max line. Is that even possible with the amount i put in considering where the level was before? On top of this there was a bunch of milky gook on my dipstick, but from what I read on here that is normal in the winter. Also I lost my mazda zipper folder with the manual, warranty info, and mazda 24 hour roadside stickers etc., anyone know how i can replace that stuff?
Old Dec 8, 2004 | 06:29 PM
RotaryNoob's Avatar
Hi
Give the oil a couple minutes to settle and check it again... Either you read it wrong the first or second time.
Old Dec 8, 2004 | 07:31 PM
zoom44's Avatar
contact your dealer or mazda customer assistance (1-800-222-5500) to replace the stuff you lost.
Old Dec 8, 2004 | 07:36 PM
Owens's Avatar
thanx for the replies...its dark out where I am so i'm gonna have to wait till 2moro before i can check it again....if somehow i did read it wrong the first timewhat should i do ab out the oil level being over the max line? take it to my dealer to drain?
Old Dec 8, 2004 | 07:42 PM
philodox's Avatar
Rangers Lead The Way!
It's easy to drain it yourself.. you can actually get to the oil pan if you jack up the passenger front tire, get a coffee can and open the drain plug.. let about 1qt drain out and put the plug back on. Wipe the oil off the oil pan and check the levels again. Then fill it to specs.
Old Dec 9, 2004 | 01:59 PM
Nubo's Avatar
Lubricious
Just in case it isn't obvious (you never know) -- Don't unscrew the drain plug all the way, just enought to drain off the excess oil slowly.
Old Dec 9, 2004 | 02:10 PM
philodox's Avatar
Yeah, always use a bit of common sense when doing anything with your vehicle
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
