Help....!!!
Old Nov 27, 2004 | 03:23 PM
speedaholic's Avatar
Exclamation Help....!!!
Today i remove my 8 catalystic converter replace it with normal mid pipes with no cat converter but the sensor still inplace, i think i can get more HP out of it well im wrong an hour ago i run my 8 0-100 Km/h drag and my time drop 2 sec from 5 to 7 sec and below 6000rpm the responce also drop, after that i install "lamda folder" and the check engine light turn on even so i scan it dont work, remove battery for 3 menit so it can reboot also dont work and still power is lost.
i runs out off ideas, i hope my fellow 8 lovers can help me out. thanks...
"lamda folder" = device for manipulating ecu so it still think the co level is right, i install it after the cat converter sensor
Old Nov 27, 2004 | 04:00 PM
snap-on's Avatar
Why did you bother re-installing the sensor with no converter?
Old Nov 27, 2004 | 05:36 PM
RotaryNoob's Avatar
Hi
Old Nov 27, 2004 | 05:43 PM
Charles R. Hill's Avatar
Owner of BHR
I re-installed my sensor with no cat because I needed it to plug the hole. Probably the same with speedaholic, here. He should also realize that the CEL is passive.
Charles
Old Nov 27, 2004 | 05:59 PM
Doctorr's Avatar
Ricer is Nicer.....
Lamda folder no workee.....
Sounds like you connected the "lamda folder" (O2 fooler) wrong, upsetting the ECU.
Check you have the two right wires, sensor and sensor ground, not the heater power & ground wires.
doc
Old Nov 27, 2004 | 06:22 PM
snap-on's Avatar
Sorry guys..I didn't read the last part. (It was quite a struggle)
Sounds like we need a code here to see what the problem is.
Old Nov 28, 2004 | 06:08 AM
Red face Sorry...Guys...!!!
ha..ha...sorry my english is bad, i hope you get the picture..!! today i remove the 02 fooler but my check engine light dont turn off, maybe the problem is in cat converter sensor get wrong reading,
"good news" my power is back
"bad news" check engine light on
what should i do if the cat converter replaced with normal mid pipes with no cat converter...???
any suggestion....??? and i'm very sorry if you guys have trouble reading my english becouse i got C in english class ha...ha..
Old Nov 28, 2004 | 06:17 AM
Red face
ha..ha..i hope you get the picture, sorry my english is very bad becouse i got C in english class!!, Today i remove the O2 fooler, some of my power is back but check engine light still turn on.
What should i do if the cat converter is remove and replaced it with normal mid pipes with no cat converter....??
any suggestion..??
Old Nov 28, 2004 | 11:53 PM
sandia8's Avatar
car for 2 and the dog
hope u no drive in my state.
Old Nov 29, 2004 | 12:16 AM
RotaryNoob's Avatar
Hi
Ignore the light or put your cat back on... Those are your choices it seems.
Old Nov 29, 2004 | 06:43 AM
In Indonesia is legal for a car without Cat converter, so what the hell as along it gives me more power.
and I intend to fix that engine light problem then if next saturday the dyno said I lossing WHP I will put back the CAT.
Thanks.
Old Nov 29, 2004 | 07:04 AM
stasis1's Avatar
speedholic,
u sure that ur 8 cant run 0-100kmh in 5 sec? and which old airfield? As i know there is only 1 PRJ
Old Nov 29, 2004 | 02:00 PM
Thumbs up !!!!
Oooohhh...!! you've been to PRJ Stasis1? nice long open road wright!
where exactly do you live?? except between countries!
My 8 clocked 5.6 sec exactly in the verricom device!!
I got 220 WHP in butt dyno, that before I removed the CAT!!
and I got good news, Charles R. Hill says that engine light on because CAT removed is not a problem and not lowered WHP!! I can wait to see the dyno result! "all finger crossed"
Thanks to all of you, you guys have been much helpful to me!!
Thanks a lot
Old Nov 29, 2004 | 02:10 PM
:)) ;))) Rx-8 Rules....!!!
One more thing!!
Guess what??
I smoked Nissan 350Z this day !!
I'm so Happy this day, cause I hate 350z a lot!! many people said that 350z faster than RX-8, well they are wrong! I proved.
I love RX-8 so much, even I have to chose my 8 or my girlfriend! I chose my 8. ha..ha..ha...!!!
Hat off to MAZDA, thanks for building this fantastic machine!!
Old Nov 29, 2004 | 11:16 PM
ypwpat's Avatar
i assuming that you smoke a Stock 350Z , but well done
What exhaust did you put on your 8? we are hoping to get Fujitsubo on.
Can you give me the detail of your Headers? Where you make it in Indo.
Cheers
Old Nov 30, 2004 | 12:02 AM
snap-on's Avatar
https://www.rx8club.com/series-i-tech-garage-22/done-removed-my-catalytic-converter-46037/
Can we combine these threads..?
I want to see how this turns out..
Old Nov 30, 2004 | 02:04 AM
Smile !!!
Yes, stock 350Z but it still feels good!!
my exhaust is RB, and I make my header in "KARYA JAYA" muffler shop located in Jl. Palmerah ( direction : if you came from MPR building you turn left at the traffic light, after you turn left it placed 20 m in the left )
ypwpat I noticed that you have an 8 in Indonesia, maybe next time you in town we can meet up!!
Old Nov 30, 2004 | 02:11 AM
ypwpat's Avatar
sure no problem, Where about do you live? We live in JKT-Utara in Sunter. So far the only mod we have in the car is Rotary Extream Intake :P You happy with the Headers Quality Built? How much in Rp if i may know. Where in Indo got the Unichip dealer? and How much?
THanks
Old Nov 30, 2004 | 05:01 AM
Question !!
Hey...are you Indonesian guy?? I lived at Jl. Gunawarman or Jl. Tebet Raya No.52 Jak-Sel!!
I'm not very happy with my header cause my mechanic said that it has poor quality steel and I intend to change it if I got spare money, until then I stick to what i've got after all maybe it's better than stock it have polished inside pipes so is very smooth!!
You've got to go to Sigma Speed !! the owner ( Soleh ) and his son (Boy) are very good mechanic " best in Indonesia"!! Unichip cost me abaut Rp. 3.500.000.- that priced included tuning and dyno testing!!
I intend to go there this saturday maybe you can come along!!
Old Nov 30, 2004 | 05:42 AM
ypwpat's Avatar
well it would be great but i'm still at Melbourne , but i'm going back soon.
foxyminx40
Mar 29, 2013 02:25 PM
Tregan
Series I Engine Tuning Forum
Jan 23, 2013 06:54 PM
Kiwirx8888
Oct 17, 2012 06:34 AM
eche4183
Jun 26, 2012 11:02 AM
slavearm
West RX-8 Forum
Sep 27, 2006 04:37 PM
