Programming keyless entry
Old Oct 23, 2004 | 11:14 PM
djgaston's Avatar
I tried to program my keyless entry today, I bought new remotes off of Ebay. They have batteries in them but the batteries "could" be dead I guess.
I do the instructions and everything works great, except when I push buttons on the remote. I then take the key out and it locks/unlocks a couple of times and nothing works. Here is what I am doing:
Programming Instructions
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock
switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do
this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off)
position.
Step 5: Close and open the drivers door 3 times. Leave door open after
this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking
and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a
final time with a series (about 4) of door locks and unlocks.
Old Oct 23, 2004 | 11:26 PM
snap-on's Avatar
does the car go into "programing mode?
Btw it's easier to push the little black button vs opening the door three times.
Old Oct 23, 2004 | 11:42 PM
djgaston's Avatar
Yes the car locks and unlocks once and then I push any button on the keypad twice and then remove the key from the ignition. It locks, unlocks, locks, unlocks, and then nothing works. It's pissing me off.
Old Oct 23, 2004 | 11:46 PM
snap-on's Avatar
The batteries must be dead..
One the mode is accessed and the fob buttons are pressed twice...(the locks should cycle)
The car should retain the freqencies.
Old Oct 24, 2004 | 12:10 AM
djgaston's Avatar
Figures... I'll get some new batteries next time I am in wal mart and try it again. Thanks.
Old Oct 24, 2004 | 11:28 AM
jniamehr's Avatar
Young Rotor Head
What kind of remote did you get? is it a mazda remote, or can it be any remote?
Old Oct 24, 2004 | 05:19 PM
djgaston's Avatar
No they are Mazda remotes, you can buy them off of Ebay pretty cheap. There are two sellers that stock them.
Old Oct 24, 2004 | 09:24 PM
Kel Rx8's Avatar
if your not 1st your last
just in case u migth want to do a search on my post .i bought one of ebay too a guy in nj
but they never worked.so i gave it to my brother he has a mazda 6 and yeah it worked for him.its a oem mazda keyfob but not for the rx8.oh well hope you're not having the same problem.
Old Mar 1, 2005 | 05:04 AM
brothervoodoo's Avatar
RainMan is Back
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7941761626
Eraser
Aug 11, 2023 11:31 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
crimson809
Aug 14, 2016 10:03 PM
Hdez Mex
Sep 24, 2015 02:47 AM
