Beeping- at 75 mph or more
Old Oct 8, 2004 | 07:42 AM
Frank Patrick's Avatar
Anyone know why I get a beeping- when I hit 75mph- continues to beep until speedo drops below 75 (AT) ?
Old Oct 8, 2004 | 07:55 AM
titaniumgrey's Avatar
18 year old speed freak
lmao ..... thats the redline buzzer isn't it ? It's telling you , that your approaching redline ...
Old Oct 8, 2004 | 08:24 AM
at 75?
Is there a way to reset that beep- it should not be going off at 3100 rpm/75 mph right?
Old Oct 8, 2004 | 08:31 AM
therm8's Avatar
Bummed, but bring on OU!
what kind of beeping? beep-beep-beep or beeeeeeeeeeeeep. Not that i know the answer to either but someone might :D
Old Oct 8, 2004 | 08:47 AM
czr's Avatar
czr
RX8 RX8!
Do the AT's have shift tones? If they don't even have it, that wouldn't be it. Have it checked out pronto.
Old Oct 8, 2004 | 09:25 AM
It's a beep-beep- at 75 mph- 3100 rpm- but not related to rpm- for example, taking up to 3100 rpm in neutral wil not set off the beep-there has to be simple way to reset-just do not know how-
Old Oct 8, 2004 | 09:33 AM
MyRxBad's Avatar
Fb's rock!
When you power up the car, do all the warning lights illuminate for a few seconds while in "test" mode. Just making sure it isn't a warning light that's burnt out.
Old Oct 8, 2004 | 11:28 AM
Ole Spiff's Avatar
Do any of the warning lights light up? Any symbols suddenly appear on the instrument cluster? Does it beep a few times then stop? Or does it keep beeping as long as you're at 75 or higher?
Old Oct 8, 2004 | 01:31 PM
Ellar's Avatar
Maybe a TPMS sensor is sending wierd signals to the receiver? I know it's not supposed to sound any tone above a certain speed, but check your tire pressures. See if the dealer can run a diagnostic on that system.
Old Oct 8, 2004 | 02:04 PM
Thanks- I appreciate all of these ideas.
Old Oct 8, 2004 | 02:50 PM
Labop's Avatar
The only time I've heard a beep at a particular speed was in Bahrain. In some Mid East countries, it's law that a warning buzzer goes off about 100 KHP (it's been two years, forgot the exact speed). We just used to turn the radio louder. Never heard of it in an American car though.
Old Oct 8, 2004 | 05:19 PM
Mistryl's Avatar
Funny, and here i am, hoping to find a way to get my car to tell me when i'm speeding...
Old Oct 8, 2004 | 05:33 PM
mspeed11's Avatar
drift addict
have you disconected the battery for a few min? i would before i took it in!
Old Oct 10, 2004 | 10:26 PM
SWSDuvall's Avatar
I too had the beeping
Hi,
I had my instrument cluster replaced.. When they put in the new cluster I had the beep at 75 mph - DROVE me crazy.
University Mazda, Seattle conferenced with Mazda California and Japan and they could NOT diagnose it. They dug into the PCM, cluster, you name it.
In the end - NEW intrument cluster - beeping went away. And they thought I was off my rocker when I first told them about it. I said - Here's the keys. The mechanic came back speechless.
So, I am on my 3rd cluster (orig replace with beeper, then 3rd to fix the beeping). The good thing is I have 8,500 LESS miles on my odometer as the miles get reset on each new cluster
Steve
Old Oct 11, 2004 | 12:02 AM
Easy8's Avatar
I thought that I was loosing my mind!!! Mine does the same thing, I've re-read the OM, tried every setting and button in the car. My next step in back to the dealer I guess. Just had the car a month so I hope there is not an issue with correcting this. I'll keep you posted, and thanks for the post!!
Don
Old Oct 11, 2004 | 12:14 AM
MazdaManiac's Avatar
Steve
No sticker in your doorjamb? They are required by law. It is a felony for the dealership to replace the cluster without a sticker and it is a felony for you to sell the car knowing it was replaced and not disclose the discrepancy.
They won't put you in with Martha Stewart, either.
Old Oct 11, 2004 | 12:31 AM
Mistryl's Avatar
hmmm....i wonder if i can GET the beeping....anyone know of any way?
Old Oct 11, 2004 | 08:54 AM
WHealy's Avatar
Mr. Blue Man
Yeah. When I had an instrument cluster replaced in a previous car, they had to hold the car while they waited for a PRE-SET MILAGE cluster to be delivered. As in I coulnd't put more miles on it until they delivered the one with identical miles to replace the old. They said it was a government reg.
Old Oct 11, 2004 | 01:11 PM
zoom44's Avatar
there is a Can module that records the mileage that is supposed to be used to set the mileage on the new cluster. if its not done correctly then you can lose mileage. but it would have to be noted somewhere. as mentioned above this is illegal to roll back an odo.
Old Oct 11, 2004 | 03:26 PM
Beeper from He--
The beeper noise is coming from my cluster- there has to be a way to reset-without going through a whole new cluster!
Old Oct 29, 2004 | 10:13 PM
Mazda Monkey's Avatar
Hi,
Steve
It's not a problem with the cluster. The problem occured when the dealer replaced the cluster & did not program it for the USA spec. If it is not programmed to USA spec, you WILL get the 75MPH beep as a default. The fact is, the dumb *** dealer did not program the cluster the first time, rather the third.
Old Oct 30, 2004 | 02:57 AM
Mistryl's Avatar
hmm...can i program the cluster with the japan program then? I actually would like the beeping above the 75 mph...anyone know?
Old Oct 30, 2004 | 03:29 AM
alnielsen's Avatar
Question: Why would the dealer replace the original instrument cluster, which created this problem? Was it done before you recieved the car? Is the dealer trying to get rid of miles on the car so they can sell a demo as new?
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Forevermore
Sep 20, 2015 01:04 PM
Jonesboy2398
Sep 13, 2015 05:28 PM
titaneum_grey
Sep 6, 2015 10:21 PM
stickmantijuana
Sep 4, 2015 10:31 PM
