Help i want to remove the whole stock intake . should i do it please i really need he
Old Oct 2, 2004 | 05:09 PM
eclps0's Avatar
Unhappy Help i want to remove the whole stock intake . should i do it please i really need he
I just took off my front bumber, i want to take teh stock intake piping out. my only concern is that there is a vacum hose to open up the fresh air duct. is there a way to bypass this or should i just leave it alone. there is alos a little black cage thing around teh fresh air duct should i aslo remove it ,
i ahev enclose some pics
the first pic and 3rd pic is the stock intake with fresh air duct.
the 2nd pic is the black box thing i was talking about.....
4th pic is car with no bumber
Attached Thumbnails Help i want to remove the whole stock intake . should i do it please i really need he-dsc00066.jpg   Help i want to remove the whole stock intake . should i do it please i really need he-dsc00067.jpg   Help i want to remove the whole stock intake . should i do it please i really need he-dsc00068.jpg   Help i want to remove the whole stock intake . should i do it please i really need he-dsc00069.jpg
Old Oct 2, 2004 | 05:56 PM
Doctorr's Avatar
Ricer is Nicer.....
Disassembly.....
That system is called the VFAD long & short runners.
It is doing nothing constructive, now that you are taking warm air from behind the rad, instead of the 'tuned' cool air intake you had before.
You will get slightly cooler air to your filter if you take out that piping, but not much.
The only cold air is in front of that hole, anything that sucks 'aft' of that (Like that huge K&N you have....) is taking in radiator backwash. :o
doc
Old Oct 2, 2004 | 07:10 PM
rotarygod's Avatar
Since the K&N isn't in it's own sealed box where the intake pipes directly feed it, you aren't getting any benefit by having them there. Remove everything and plug the vacuum line. Definitely find a way to get some shielding around that filter so hot engine bay air isn't being ingested. You are LOSING power over stock if you don't. Hot air is less dense air. Less dense air is less air. Less air is less power.
For the record if you go to K&N's website and look at their before and after dyno charts for the intake, It showed a 9.5 hp gain over stock. If we look a little closer we see that the runs were taken 3 days apart and the temperature difference was 10.7 degrees F colder when their system was tested! This doesn't even mention humidity difference between the 2 days. It also doesn't mention engine temperature. Of course they showed a gain!!! If they'd have dyno'd the stock system that day, they'd have made more power than the first run too. If in fact they ended up getting any gain at all, it was only because flow was increased at the expense of intake box tuning. They got alot more noise though. I hope you enjoy the sound of the K&N. That's what it is there for.
Old Oct 2, 2004 | 07:12 PM
eclps0's Avatar
i took it out for the aem cold air. i plan on getting it when its released....
but thanks for help
Old Oct 2, 2004 | 07:37 PM
310Guy's Avatar
4AT poor mileage king
Originally Posted by eclps0
I just took off my front bumber, .....
Sorry but I can't stop laughing at that: bumber.
What part of the car is that???
Old Oct 2, 2004 | 08:15 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Was thinking the same thing... but the scary thing is there are 80+ threads with it spelled 'bumber'. It's not like the 'b' and 'p' keys are near each other, so apparently it's a new car part that I didn't know about :D
Old Oct 3, 2004 | 06:06 PM
Tony Orlando's Avatar
Bored thread resuscitator
No no.... It's a new part of teh car we don't know about.... Seriously, are internet forums destroying my beloved English language, or are they just bringing it to my attention?
rotorocks
47
May 11, 2016 03:23 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
RXeckless
Aug 16, 2015 12:51 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
