What The hell my rx8 flooded with 25,000 miles
Old Sep 26, 2004 | 03:46 PM
eclps0's Avatar
What The hell my rx8 flooded with 25,000 miles It has a metilic sound when i crank it
it flooded or i had engine failor it wont crank over at all it dosent even sound lie its going to. I have the m flash and have 25,000 miles on it
Old Sep 26, 2004 | 04:02 PM
eclps0's Avatar
damm huricane they cant pick up my car till maybe tommorow
Old Sep 26, 2004 | 04:19 PM
cgrx's Avatar
DRIVEN
Could your battery be dead ?
Old Sep 26, 2004 | 04:20 PM
Ellar's Avatar
I can hear him on the phone now: "What the hell do you mean, 'My Towtruck is on the roof'? Stop playing games, get it down and come get my car!!!"
Old Sep 26, 2004 | 04:21 PM
eclps0's Avatar
no battery is fine. i tried cranking it over 10 times nothing. It sounds like a metilic sound
Old Sep 26, 2004 | 04:24 PM
eclps0's Avatar
lol
you have no idea....... :D ........
Old Sep 26, 2004 | 06:05 PM
snap-on's Avatar
If the solenoid is clicking it's not gonna start. Get a jump
Old Sep 26, 2004 | 06:19 PM
Omicron's Avatar
Exactly. Sounds just like a nearly dead battery to me.
Old Sep 26, 2004 | 06:40 PM
cgrx's Avatar
DRIVEN
told you
Old Sep 26, 2004 | 07:43 PM
6speed8's Avatar
are these your symptoms:
https://www.rx8club.com/rx-8-discussion-3/unable-start-engine-40219/
Old Sep 26, 2004 | 07:51 PM
snap-on's Avatar
Now Now Now...don't go hooking these threads together.
That makes to much sense.
Old Sep 26, 2004 | 07:53 PM
cgrx's Avatar
DRIVEN
LOL
Old Sep 26, 2004 | 10:23 PM
eclps0's Avatar
nope
its not the battery i jumped it and it does the same damm thing. My friend with a 2nd gen rx7 thinks its blown because he heard the metailic sound when i crank it. And he also smelled the gas in the oil.
Old Sep 26, 2004 | 10:31 PM
snap-on's Avatar
make sure you are connecting the jumpers correctly.
Ask your friend when he smelled the oil what level of oil/fuel ratio he estimates bases on a sniff test.
Old Sep 26, 2004 | 10:37 PM
RotorGeek's Avatar
Still spining
That sucks man I hope you get it fixed.
Old Sep 26, 2004 | 11:03 PM
eclps0's Avatar
trust me guys i had a mitsu eclipse which would always die i know how to jump a car. Now with the oil it smelled like more gas. after i tried cranking it i would step out of the car and smell lots of gas. Also when it cranks it wont turn over and its a nails against chalk board sound ( sounds like the seals grinding against the walls) my friend with the 2nd gen said if the engine gets flooded enough it will wash away all of the oil which lubes the seals and housings so basically what is happening when i crank the engine is the seals are digging into the housing or chattering. Which in turn means rebuild with new seals./ rotors or a new engine.
also the lights and everything else were off so my bad was good it was only sitting for a day in my garage during the huricane
Old Sep 26, 2004 | 11:15 PM
snap-on's Avatar
So stop trying NOW..
Call road side asst an get the car to the dealer.
Old Sep 26, 2004 | 11:26 PM
eclps0's Avatar
i know
i stopped trying to crank it. beacuse of this dumb hurricane they dont know when AAA can pick up my car.
Old Sep 27, 2004 | 08:16 AM
eclps0's Avatar
No Compression
tow truck guy came he was working as a tow driver for about 30 some odd years. He told me my car sounds liek it has no compression, he checked teh battery it was fully charged he thinks my engine is bye bye. Also i have my K&n intake on tehre i hope mazda wont give me a problem. K&n garenties it wont void your wareenty so it shouldny be a problem.
Old Sep 27, 2004 | 08:20 AM
Air Force RX8's Avatar
Who Cares?
Good luck, let us know what the outcome is...
Old Sep 27, 2004 | 08:33 AM
RotorGeek's Avatar
Still spining
I hope it turns out ok for you.
Old Sep 27, 2004 | 09:41 AM
eclps0's Avatar
guys
i found out waht it was i had alott of water in my engine. tehy have it running now theya re going to test it to see if its ok
Old Sep 27, 2004 | 09:48 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Did you drive through deep water and forget about it??
Old Sep 27, 2004 | 09:50 AM
RotorGeek's Avatar
Still spining
That would have been some deep *** water.
Old Sep 27, 2004 | 10:11 AM
G8rboy's Avatar
That makes me wonder about the secondary VFAD flap-actuated intake duct that sucks from down low in front of the radiator... it wouldn't take too much water (less than 1 foot?) to get that duct underwater, but it would seem to me that with the primary air duct dry and sucking more air, you'd really have to be revving high and hard to get water sucked up there (7250RPM+).
I'm not sure where the primary duct is height-wise, but I would imagine that would really take some deep water to get you into trouble.
