would removing your cat increase your gas mileage?
Old Sep 15, 2004 | 04:47 PM
brillo's Avatar
Go Texas Longhorns!
I know pulling the cat would free up some HP, just b/c its a restriction, but I was wondering if it would also improve mileage in any way...all environmental issues aside....
Old Sep 15, 2004 | 04:55 PM
mysql101's Avatar
definately if your car stopped dumping fuel on it to keep it cool. but then you wouldn't need to remove it
Old Sep 15, 2004 | 04:58 PM
Rxdriftingaction's Avatar
it won't got a big help. don't do that man.. maybe will increase 2~3hp. but u won't get some good deal with mpg. maybe will got worst.
Old Sep 15, 2004 | 05:33 PM
MELRX8's Avatar
"RX-8 my stress reliever"
Which is the greater restriction, cat or stock exhaust? In other words which will improve flow the most a high flow cat or after-market exhaust?
Old Sep 15, 2004 | 11:25 PM
robertdot's Avatar
Go read racing beat's site. They talk about all that.
Rxdriftingaction, where are you from?
Old Sep 16, 2004 | 09:02 AM
brillo's Avatar
Go Texas Longhorns!
Old Sep 16, 2004 | 09:26 AM
StealthTL's Avatar
Metatron
Experiment underway......
I am running that experiment this week, will keep you posted on the results.
I removed the 'oxidation' bed of the catalyst, by far the biggest restriction. I retained the 'reduction' bed, (the first bed, before the secondary sensor) thus avoiding check engine lights.
I just finished my first tank of gas after the switch over, but don't want to quote results based on just one fill......
Will post next week.
S
(Anyone interested in detail can P.M. me, but don't go carving up your cats just yet.)
Old Sep 16, 2004 | 09:36 AM
brillo's Avatar
Go Texas Longhorns!
Interesting, how is the noise level?
Old Sep 16, 2004 | 09:38 AM
robertdot's Avatar
The problem with the gas mileage is the ECU fuel maps, not restrictions. It still going to run rich if the cat is there or not, and it is still going to get bad mileage.
Old Sep 16, 2004 | 09:57 AM
StealthTL's Avatar
Metatron
Noise....
Sounds louder, no doubt, but not any 'harsher'.....
I have a cat-back, it just makes the grumble and 'poppage' louder, if you know what I mean.
s
Old Sep 16, 2004 | 10:23 PM
Felix W.'s Avatar
cat removed - no CEL?
So how can you remove the cat, yet not get CEL codes? Do you use an O2 fooler?i don't understand which part of the cat you removed to reduce backpressure.
felix
Old Sep 17, 2004 | 03:22 AM
robertdot's Avatar
Trick it with an O2 "fooler". Remove the whole thing. Cats are restrictive by their nature. You are shoving exhaust through tiny "honeycomb" holes. Remove it, replace it with a straight pipe, and it flows better. It's not going to increase your mileage (at least not enough to deal with the extra sound), and your HP increases are only marginal (according to Racing Beat).
Old Sep 17, 2004 | 08:49 AM
shelleys_man_06's Avatar
Not anymore
Agreed. Removing the cat will cause some gains in power, but I don't think it will increase gas mileage. You're freeing up more area for flow. I believe your engine will increase in thermal efficiency on the order of 0.001%.
Old Sep 28, 2004 | 12:43 AM
Not anymore
Okay. I'm seriously thinking about removing my cat, permanently, but I'm worried about my upcoming emissions exam. Yeah I call it an exam; it's worth 30% of my RX-8's grade for the semester. Seriously, are there any solutions to passing the emissions test without a cat in Texas?
Old Sep 28, 2004 | 01:07 AM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
Someone on here posted once about how they passed their tests without their cat. I believe it was something along the lines of a heat sheild? or something encasing his mid pipe, so when they pull out the mirror and look under the car, it looks like there is actually a cat. Don't take my word for it, as I don't know the regulations for emissions testing in Texas or any other state. But if all of what I just said was wrong(good probability) couldn't you just strap the cat back on the day of the test? Again I don't really know how long or how much work it would take to switch back on. Hope this helps.
Old Sep 28, 2004 | 01:13 AM
IZoomZoomI's Avatar
Boost needed
isn't most the restriction from the exhaust manifold and not the cat?
Not anymore
Well, rotaries are pretty damn loud without cats. As for the RX-8, I really don't care at this point in time. Like I said, I don't want to have to crawl under the car the day before the test just to put my cat back. I'm a lazy SOB. Plus, it would've been a clear sign I should've just kept it there in the first place. I'll figure something out. shelleys_man_06 always has a solution, even if it's crazy.
Old Sep 28, 2004 | 01:22 AM
It's just one day a year, c'mon. But seriously if you are really against having to do that, there is always the high flow cat option.
Old Sep 28, 2004 | 07:05 AM
Not anymore
I'll admit the exhaust manifold is of a log-type. I prefer a long-tube header, but I don't know if that would fit. I know some aftermarket companies have them, but I'm looking forward to designing a turbine header.
What part of "I'm a lazy SOB" do you not understand? J/K p
Old Sep 28, 2004 | 07:18 AM
Rasputin's Avatar
Correct, unless you also make the following changes :
- disable catatyst temp protection (not advised as it also protects other exhaust hardware and sensors!) ;
- enable part throttle lean running in the map governing requested AFR (I'd love to be able to do this).
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
