Fix for issues with CZ units in GB #2
Old Sep 13, 2004 | 01:55 PM
RPIRX-8's Avatar
Apexing at Oak Tree
Post Fix for issues with CZ units in GB #2
Well, after much trial and tribulation, A fix has been found for folks experiencing very sluggish performance with the new ignition board in the CZ units shipped with GB #2 (much thanks to Canzoomer and Speed Racer for their assistance).
Yesterday after spending a second day of testing and editing the maps with Speed Racer, no progress was being made. At the time where we reigned in Canzoomer for assistance, we were at -29 on the Airflow table and -13 on the ignition table (in the problem areas). These changes were having no effect because the knock sensor was causing the ECU to retard the airflow and ignition timing to around 7 degrees or less (worst was 3 deg). After calling Maurice and talking it over with him, he asked to to detach the two light brown color capacitors from the daughterboard (see attached image). After disconnecting these 2 caps, the car came to life. We used the CanScan cable and software to take readings during 2 runs to confirm the fix.
Canzoomer should be posting some information in addition to this soon. In the meantime, let me know if you have any questions, or you want to see the data logs.
Attached Thumbnails Fix for issues with CZ units in GB #2-cz-capacitors1.jpg
Old Sep 13, 2004 | 02:23 PM
The_Bean's Avatar
Great thanks for the info.
Just another reason I've kept mine pulled out, but not yet returned. I don't think the fix works like it should.
Ben
Old Sep 13, 2004 | 02:29 PM
Speed Racer's Avatar
Certified track junky!!!
Before everyone tears their units apart to cut out the caps I'd suggest doing some data logs and going over them with a fine toothed comb first. We also found it helpful to use the map trace function in the eManage Support Tool. The first time that we tried the map trace we noticed that the unit did not recognize when the throttle was depressed. So we recalibrated the throttle position sensor and as you can imagine that helped out quite a bit.
With the throttle position sensor fixed, the unit was now able to select the appropriate values from the map tables but we were still having severe problems with pinging in the lower RPMs. It sounded like he had a bag of Jiffy Pop under the hood. Once we got the RPMs up to 5k the car felt great and responded well to changes in the maps.
After reviewing the logs we noticed that Justin's MAF sensor was reading consistently lower than mine. When we swapped the MAF sensors we still ran into pinging at the lower RPMs but it was not nearly as severe. We also tried swapping air flow and ignition maps but that actually made things worse.
When it was all said and done we ended up spending a lot of time and effort to rule out all of the possible causes before we resorted to hacking the board. In case you are wondering, Maurice told us which caps to remove. Through it all Maurice was great to deal with and put up with all of our questions and phone calls. Now that the caps are removed the car runs great and pulls strong all of the way to redline. :D
Old Sep 13, 2004 | 02:53 PM
Xyntax's Avatar
THREAD KILLER
Nice. Could you guys post the excel log from canscan? I sure would like to compare it to mine.
RPIRX-8's Avatar
Apexing at Oak Tree
Very good point Speed Racer All in all approximately 14-16 hours of attempted tuning was put in on my unit (double that if you add Speed Racer's time spent with mine) before we calling Maurice and cutting the caps off the PCB. The CanScan tool was invaluable in this task. You really can't properly tune the unit without one.
Again, please ping me with questions if you have any.
Edit: just read Xyntax's post. If you would like a copy of the data logs, pm me and I will email them to you. There are a lot of logs.
Old Sep 13, 2004 | 02:56 PM
Sea Ray's Avatar
I just got a call from Hillary saying my unit is shipping back today with the latest upgrade. She said that the newest fix was done yesterday, does that sound like he may already be doing this to our upgraded units? Sure hope so, sounds very encouraging.
Old Sep 13, 2004 | 03:06 PM
PUR NRG's Avatar
Do you know how removing those two caps changed the board? I vaguely recall Maurice added some caps to eliminate ignition coil burnout. If these are those then what happens to the coils?
________
Lovely Wendie99
Old Sep 13, 2004 | 03:15 PM
RPIRX-8's Avatar
Apexing at Oak Tree
This is true, I spoke with him and verified removing these caps will NOT cause coil burn out. There are other caps on the daughterboard (brown with black stripes) that will prevent the coils from burning.
Old Sep 13, 2004 | 03:16 PM
Maurice mentioned that the caps were there to smooth out the signal and help with a rough idle that some people were having.
It is my understanding that the diodes are doing more to protect the coils as they lower the triggering voltage.
Old Sep 13, 2004 | 03:23 PM
Magic8's Avatar
Mazda Mole
With the throttle position sensor fixed, the unit was now able to select the appropriate values from the map tables but we were still having severe problems with pinging in the lower RPMs. :D
So how does one go about recalibrating the throttle position sensors. Is it in the manual? I'm at work right now.
Did maurice indicate what these caps are for? Was it the filter to help eliminate burnt coils?
Edit,
just saw your earlier posts
Old Sep 13, 2004 | 03:30 PM
I should rephrase that and say that we calibrated the throttle position sensor with regards to the CZ unit. You'll need the eManage Support Tool (aka CZ programming kit) to make the changes. It is really easy to do.
It prompts you to take your foot off of the pedal so that it can record the 0% position. Then it prompts you to push the pedal all of the way to the floor (don't try this with the car running). Done!
Old Sep 13, 2004 | 03:50 PM
Xyntax's Avatar
THREAD KILLER
oh... *note to self: get clone cable somewhere*
Old Sep 13, 2004 | 03:52 PM
Magic8's Avatar
Mazda Mole
Forgot to ask the question earlier.
Did removing these two brown caps eliminate the throttle below 5K AND the rough idle problems?
I'm also curious, were these two caps added by Maurice or did they come with the eManage?
Great work guys. Really helpful.
Old Sep 13, 2004 | 03:57 PM
Yes, the car runs great at all RPMs.
The caps are part of a secondary circuit board that Maurice added to the eManage.
Old Sep 13, 2004 | 09:41 PM
Mauice sent me some picts of the daughter board fix. You need to clip the capacitors, and depending on the version you may have to remove two jumpers, and add 1n4148 diodes.
He has said that if the unit works on your car you do not need to remove the caps...it doesn't do this on all cars
Compare your unit to the pictures, and modify it to be the same as the after picture
Attached Thumbnails Fix for issues with CZ units in GB #2-before.jpg   Fix for issues with CZ units in GB #2-snip.jpg   Fix for issues with CZ units in GB #2-after.jpg
Old Sep 14, 2004 | 04:15 AM
IZoomZoomI's Avatar
Boost needed
wow, just did mine, works way better now. I've been trying to get this thing working for awhile, maurice could have told me this earlier... o wells, im a happy camper :D
Old Sep 14, 2004 | 08:48 AM
Maurice just found out about this fix to this specific issue on Sunday. So I wouldn't bash him for not sharing the info.
Old Sep 14, 2004 | 12:11 PM
So what would you recommend?
Old Sep 14, 2004 | 01:36 PM
GeorgeH's Avatar
So, if we clip these diodes, are the coils now at risk again?
Old Sep 14, 2004 | 02:34 PM
GeorgeH's Avatar
Gotcha - just re-read the original post. We are clipping caps and, possibly, adding diodes.
Old Sep 14, 2004 | 02:37 PM
GeorgeH's Avatar
So, how can we tell if we need to remove the jumpers and add the diodes?
Old Sep 14, 2004 | 03:01 PM
megauo's Avatar
I might be wrong here but 1N4007 is quite slow for anything above 50 Hz. How can it handle the ignition at 9KHz? Not sure though...
Old Sep 14, 2004 | 05:06 PM
epitrochoid's Avatar
Riot Controller
im about to snip snip, how do i determine if i need to add the diodes and remove jumpers?
i have poor under 5k performance and poor idle...
Old Sep 14, 2004 | 06:12 PM
Riot Controller
:D :D :D
HOLY SH**
it works, it works great!
Old Sep 14, 2004 | 06:24 PM
Magic8's Avatar
Mazda Mole
This is the fix. Smooth meaty acceleration everywhere. This rocks!!!!!! :D :D :D
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
