alex
09-02-2004, 04:57 PM
Just wondering if its complicated enough that a DIY should be made. Anyone removed theirs and take photos of the procedure?
alex
alex
View Full Version : how easy is it to remove stock airbox? alex 09-02-2004, 04:57 PM Just wondering if its complicated enough that a DIY should be made. Anyone removed theirs and take photos of the procedure? alex Doctorr 09-02-2004, 05:29 PM Do you mean - easy way to open airbox to get at filter? or remove airbox to install cone intake? . . . doc alex 09-02-2004, 05:39 PM Doctorr -- removing the entire airbox completely .. but minus the installation of another intake system, since people would have different kits to do that. I just want to make sure I don't do anything wrong or miss a step. alex WHealy 09-02-2004, 06:25 PM Opinion - not bad once you've done it. Fact - Check out the RE Intake Extreme How To (http://www.rotaryextreme.com/rx8intakeinstall.html) zoom44 09-02-2004, 06:44 PM i still cant get the damn thing open. i know someone put easy instructions on here somewhere but i cant remember where Doctorr 09-02-2004, 07:35 PM Battery cover off, grab the top two corners and push firmly back. The accordian tube will compress, and the whole shebang will move aft, the two pegs at front corners will be out and free, then angle up a little, keep pushing. There are two more pegs that are underneath, lift as you push, the whole clamshell assembly should now be loose. If all you need is filter access, unclip and spread the clamshell halves, the filter and housing are shaped so that the element will slide right out. If you need to remove the assembly, you loosen the big throttle body clamp, unplug the three hoses, disconnect the MAF and S-DIAS wiring and two small vac hoses. Pay careful attention to the grommets that the assembly sits in, silicone lube them if possible beacause if they come loose they fall in the rad fans/ jam them/ engine overheats/ self destructs. (Mazda has been informed of this design flaw.) . . . doc |
