new radiator cap...question about pressure
Old Aug 4, 2004 | 10:02 PM
kellybrf's Avatar
im thinking about buying one of these b/c ive always felt the original one was an eyesore, however im skeptical about raising the pressure. anyone using this or know what the standard pressure is? i know its typically 12psi (.8ish bar) but im not sure if its a bit higher being a performance oriented car. thanks!
Old Aug 4, 2004 | 10:36 PM
ScudRunner's Avatar
On time, on target
I don't remember the pressure off hand, but it is printed right on the OEM cap...
Old Aug 4, 2004 | 11:29 PM
kellybrf's Avatar
thanks, didnt think to look there its 0.9 bar, so the question becomes is a higher pressure cap going to mess up the system?
Old Aug 8, 2004 | 11:04 AM
shelleys_man_06's Avatar
Not anymore
No. It just means the coolant pressure will relieve itself at a higher pressure (bad sentence ).
Old Aug 8, 2004 | 12:27 PM
epitrochoid's Avatar
Riot Controller
why not just buy it and peel the sticker off and stick it on your oem one. i doubt its genuine MS anyway.
Old Aug 8, 2004 | 12:38 PM
Not anymore
L-O, freakin' L.
Old Aug 9, 2004 | 07:15 AM
Mr M's Avatar
Evolution of REvolution
Raising the boiling point means raising the pressure in your cooling system, which may cause hoses to blow, or even worse your radiator or heater core to fail. Best to stick to the recommended pressure for your car.
I don't know how this cap can raise "cooling efficiency". All you are doing is raising the pressure, you won't affect cooling efficiency unless you change the radiator or water pump...
I have searched all the Mazdaspeed websites I can find and cannot see this cap anywhere. I agree with epitrochoid, I suspect this may not be a genuine part...
Old Aug 9, 2004 | 07:11 PM
kellybrf's Avatar
oh im sure its not genuine
cliffkemp
Dec 24, 2024 10:48 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
olyrx7
Oct 26, 2015 09:23 AM
