probable dumb FI idea from a newbie
Old Aug 3, 2004 | 09:52 PM
darrellh's Avatar
After reading several posts here about different FI methods and their various advantages and compromises, it seems the most ideal situation would be if the ECU could dial up whatever airflow rate it wanted (independent of the current rpm) just like it does for the fuel rate. Instead of having a blower that directly generates this airflow in real-time, why couldn't someone store compressed air in a resevoir and then meter it out electronically into the intake manifold? You would even have the added benefit of getting colder air as it decompresses. An air compressor of some sort running off main belt would keep the resevoir charged. In general, the resevoir would only have to have enough volume/pressure to store the air needed to get the rpms up during acceleration. After that, the input compressor should be able to keep up with the flow demand.
I'm sure this has been considered before, but I'm just wondering why it won't work or is too impractical.
Thanks,
Darrell
Old Aug 3, 2004 | 10:03 PM
1stRX8's Avatar
I agree with the title.
A scuba tank is 3000psi and holds 80cu ft of compressed air. At WOT the 13B devours almost 500cfm - cubic feet per minute. Using 4 tanks as a resavoir and running 5psi of boost at that volume would last a few seconds and consume your trunk and back seat.
Then, if you did not want to take the tanks out - 3000psi pump shall be installed on the engine to recharge the system.
This does not take into account the enourmous danger of a 3000psi tank breach - ie explosion of aluminum shrapnel. Ouch.
Old Aug 3, 2004 | 10:05 PM
x-mann's Avatar
good answer
Old Aug 3, 2004 | 10:24 PM
darrellh's Avatar
1stRX8,
Thanks for the quick reply. I didn't know the Renesis sucked so much.
Thanks,
Darrell
Old Aug 3, 2004 | 10:30 PM
1stRX8's Avatar
The more it sucks, the better it is.
Old Aug 3, 2004 | 10:36 PM
darrellh's Avatar
Apparently a little CPR is desirable from time to time.
92trbolzr
May 18, 2025 09:04 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Trekk
12
Sep 25, 2015 03:08 PM
