AutoX alignment
Old Jun 30, 2004 | 07:36 PM
artflrs's Avatar
AutoX alignment
Does anybody have any alignment recommendation for autocross.
Old Jun 30, 2004 | 10:02 PM
B-Nez's Avatar
Try these threads:
https://www.rx8club.com/showthread.p...ment+autocross
I found them by using the following search terms:
alignment autocross
The search button is one of the coolest features of the forum.
Old Jul 1, 2004 | 01:57 PM
clyde's Avatar
www.TeamWTF.org
When it provides usable results. Only one of the three threads you linked actually had anything to say about alignment settings for autocross use and it was nearly a year old...which was a time when the first people were just getting their cars and starting the process of finding settings that worked best. Things have developed since then.
FWIW, artflrs my specs (with Koni DAs):
Front Camber: -1.4 (I'd like more, but that's all I could get)
Caster: 6.7
Front Toe: 0
Rear Camber: -1.5
Rear Toe In: 0.04
Old Jul 1, 2004 | 05:43 PM
artflrs's Avatar
i plan on getting my alignment done next week.
So, thanks for all the help.
Old Jul 1, 2004 | 08:14 PM
PUR NRG's Avatar
clyde, I'd disagree. The other posts, while they may not discuss actual numbers, still had relevant things to say about alignment settings for autocross.
A more general search on "alignment" would probably turn up additional threads with more hard numbers. Seach is still your friend.
It has been a year but I'm still a long way from sorting out my alignment...
________
Marijuana Bubbler
Old Jul 1, 2004 | 10:37 PM
PoLaK's Avatar
Son what is your Alibi?
-1.5 Camber (Front)
0 Toe
5.7 Caster
-1.0 Camber (Rear)
.12 Total Toe-in (Stock is .08)
Make sure it is done with driver in the car.
Old Jul 6, 2004 | 08:57 PM
bmc's Avatar
bmc
I'd rather be auto-xing
With stock shocks, this my alignment:
Front camber -1.4 (as much as I could get)
Caster 6.6
Front toe 0
Rear camber -1.5
Rear toe in 0.03
Brian
Old Jul 6, 2004 | 09:45 PM
red_rx8_red_int's Avatar
OK, I'm really a noob to all this, can I do an alignment myself, or do I need a reliable shop to do it?
Old Jul 6, 2004 | 09:48 PM
AlexCisneros's Avatar
is the car stock?
any sway bars?
What tires are you running?
Generic alignments aren't always a good thing.
Old Jul 7, 2004 | 07:25 AM
clyde's Avatar
www.TeamWTF.org
I agree...I recall seeing a few threads discussing alignments with more useful info than two of those three threads (but, of course, I'm too lazy to search for them myself). :D
Old Jul 7, 2004 | 07:38 AM
clyde's Avatar
www.TeamWTF.org
How accurate do you want it to be? Small changes can make a big difference.
Everything is very easy to adjust compared to most cars, but if you don't know what you're doing you'll probably wind up worse than where you started.
Having it done at a good shop is worth the money, IMO. For most people, it doesn't become worthwhile to DIY until 1) you really, really know how all of the settings affect the car, 2) need to get it dialed in just so and 3) are willing to risk screwing it up in the learning process.
Old Jul 7, 2004 | 01:49 PM
that and they aren't cheap either...
My last one cost $95 and it still needs tweaking
Old Jul 11, 2004 | 12:51 PM
Mazdaspeedgirl's Avatar
Lollygagger
Mine are free.
But we are taking the 8 on a 3000 mile trip next week and I won't be able to try anything until after her first autoX. Don't really want that annoying uneven treadwear on her only set of shoes. Did that in the miata once...ruined a good set of Toyos. :o
Old Jul 11, 2004 | 05:35 PM
artflrs's Avatar
Just had my alignment done and the maximum camber allowable on the left-front was only 0.6 degrees. Is there any way to get more camber without aftermarket products.
Old Jul 11, 2004 | 08:03 PM
what size wheel and tire are you using and with what offset? Were you in the car?
Old Jul 11, 2004 | 08:14 PM
artflrs's Avatar
stock wheels and tires. I wasn't in the car, was just trying to max out the camber upfront.
Old Jul 12, 2004 | 09:55 AM
markh711's Avatar
My front left camber was limited to about 1.2 degrees. We could get 1.8 out of the right front.
This was me out of the car. After I got in the car, the left camber stayed the same, but the right camber actually went up.
This was with 245/45R17 Falkens all around.
Mark
gwailo
May 14, 2024 06:57 AM
projectr13b
Mar 1, 2019 09:00 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
thewatcher101
Jul 27, 2015 09:44 PM
