rewiring foglights...help please
Old Jun 27, 2004 | 07:25 PM
Bet on Black's Avatar
Alopecian in a black 8
Exclamation rewiring foglights...help please
I am following the thread in the dIY thread on rewiring the foglights to run without the main headlights. I am following omicrons way and can not seem to get it to work. I am slicing the brown wire with the small red and white wire yet nothing. Any suggestions. Seems like the splice is fine, I actually tried two different ones just to make sure. So I just rewired it back the old way until I can figure it out.....anyone?
Old Jun 27, 2004 | 07:35 PM
pret's Avatar
AbsolutelyNothingHappenin
check the wires
i have followed those directions, no problems. check the wire again, some look similar red/white white/red are two different wires.
Old Jun 28, 2004 | 08:27 PM
red_rx8_red_int's Avatar
Did you turn them on via the blinker stick and have the ignition on? IIRC it's the smaller red/white wire.
Old Jun 29, 2004 | 12:13 PM
pret's Avatar
update
update to your pm, hubby used the wire from the third fuse and spliced to brown wire. ensure you splice to the correct side of the brown wire.
Bio
Canada Forum
20
Apr 13, 2012 05:06 PM
Misfyre
West RX-8 Forum
20
Dec 7, 2009 01:08 PM
wedge357
Series I Do It Yourself Forum
33
Feb 20, 2009 07:43 PM
zerocyl
Oct 31, 2007 05:44 PM
sammytcl
Dec 11, 2006 04:17 PM
