Do you forget sometimes to warm up the engine and shut it off?
Old Jun 26, 2004 | 03:36 PM
Bankotsu's Avatar
I did that this morning. I got home late last night and parked it outside bc I didn't want to wake people up to move their cars. So I moved the car this morning into the garage and the engine has only been runnin for at least 2 min. I turned off the car and I was like "aww crap, I hope its not flooded." So I waited until my sister leaves for work because I needed gas too for the RX-8.
Well I turned it back on and it didn't. It did leave a very nice smell in the garage though and lots of smoke came out.
Old Jun 26, 2004 | 03:44 PM
Spazm's Avatar
~~> Next 10 miles
SMOKE?! That doesn't sound healthy to me...
Old Jun 26, 2004 | 03:45 PM
Bankotsu's Avatar
not a lot of smoke..just enough that i can see when i look. I'm assuming its the old oil. I went to get gas and no smoke that I can see clearly after that.
Old Jun 26, 2004 | 04:02 PM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
I never warm mine up.
I just rev it up to 2k and shut it down and she has always started right up for me!
Old Jun 26, 2004 | 06:22 PM
loco4rx8's Avatar
BSG 75
Mine smokes on startup every once in a while, too. Usually after it's been sitting for a couple days - like on a Monday morning. I wash the car nearly every weekend, which involves moving it out of and back into the garage. I always let it get to the point where the needle has at least moved up to halfway between cool and the halfway mark.
Anyway, I think the smoke is often evident of a flood - or near flood. However, I'd be curious to know if it's an ominous sign.
Old Jun 26, 2004 | 06:26 PM
DOMINION's Avatar
I don't buy Kool-Aid
Mine no smokes, Only when I gun the gas then once in a blue moon I see smoke.
Old Jun 26, 2004 | 06:53 PM
Rosco's Avatar
Kew kew kew
I pull out of the garage every morning (10-15 secs. maybe) and shut off the engine in the proces of getting my kid in the passenger side, rear. Went for a month pre-M flash and going on a month with M. Never had any smoke, flooding, etc. Of course, your mileage may vary, but I'm pleased and don't even think about it any more.
Old Jun 26, 2004 | 07:03 PM
fluque's Avatar
vroooom.....
no smoke in mine
only when I spin wheels!
Old Jun 26, 2004 | 07:42 PM
VikingDJ's Avatar
Music and Cars!!! :)
Last week I dodged a bullet. I only had it running for like 2 minutes myself when moving it out of garage. About 15 minutes later when I went to pull it back in, it took a good 7-8 seconds to start, and when it did start it just kicked over, and i smelled fuel. Every car acts differently, but I know if I try and pull that stunt in winter I am definitely flooding my car. I'm not messing arounmd anymore, and will let it fully warm up, even though it is rather annoying.
Old Jun 26, 2004 | 11:31 PM
DOMINION's Avatar
To me when I had my Eclipse I would do this all the time, so I guess I'm use to it. Its just better for your car you know.
Old Jun 27, 2004 | 11:31 PM
RodsterinFL's Avatar
Friday 6/25/04 I pulled my car out of the garage and waxed it. Three hours later I went to start it and it would not start. It turned over and just kept whinying. I ran and got the manual and pressed the accelerator down and turned it over for 10 seconds - nothing. I did this about 7 times cycling between pressing the accelerator and then not depressing it. It finally started. The smell was horrible and the smoke was thick as fog. I have the M flash too. I have pulled the cr out of the garage like that many times over the past year but never had it happen until now.
Old Jun 27, 2004 | 11:39 PM
Jeffjett's Avatar
I may not always warm it up properly, but I always remember to shut it off.
Old Jun 28, 2004 | 02:39 AM
crosswound's Avatar
sometimes i forget to warm it up i just also rev it a bit before i park anywhere also when i start it. its became a habit now to rev it when i park or start it.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
vssystemluba
Jul 19, 2015 04:16 PM
