Squeal at high RPM
Old Jun 18, 2004 | 05:50 PM
Reaper Man's Avatar
I'm a bad person
Squeal at high RPM
I've searched, and though I'm not perfect on the search, I couldn't really find anything, so here it goes
I've noticed that there is a high pitched squeal when my car gets to about 6k. I'm at constant throttle and is more pronounced when I have the accelerator deeper. I'm still in the "ok" range when it comes to oil, so I'm not sure if that's it or not. Anyone else have this or you rotor gurus can tell me whether I should be worrying about this or not?
I have 2100 miles as of yet and loving every minute of it- just worried a bit , that's all
Old Jun 22, 2004 | 09:50 AM
Maz-Dawg's Avatar
May be loose accessory belts, slipping on the pulley, under 12k miles take it to the dealer and have it checked out. Easy fix, bring abox of Krispy Kreme donuts and make them your bitches!
Old Jun 23, 2004 | 02:42 PM
ByeByeHonda's Avatar
Just curious, as this maybe related to my problem... is it like a belt squealing, or like metal? Mine sounds like something might me wrong with the rotor or something. I am a little hesitant to pull up in the dealership and "Well, when she hits about 7k RPM it makes a funny noise"!
Old Jun 25, 2004 | 04:19 PM
Reaper Man's Avatar
I'm a bad person
to me it sounds like metal- as in the a problem with the rotor- as for the high rpm- to hell with them- redline is until 9k, all bets are off and they should be cool with it
I think I'll have them check it during my first oil change
Maz- first- there aren't really any krispy kremes around here, but the other thing is I don't need that stuff to make them my bitches
Old Jun 25, 2004 | 04:44 PM
zoom44's Avatar
READ MY POST TITLED "S-DAIS"
Old Jun 26, 2004 | 10:39 AM
Reaper Man's Avatar
I'm a bad person
zoom- good, that's what I thought it was originally, but I didn't know what to call it so I searched for the squeal type title and didn't find it
thanks again
Old Jun 27, 2004 | 07:55 AM
Rotary Titus's Avatar
is it a sqeal or a rattle?
Cause I had the same thing happen last week where it started rattling like crazy like something's loose and wacking around inside the engine bay at 6k rpm. Weirdest thing was I called the dealer and when I brought it in, the noise was gone and I could NOT duplicate the noise again (though I did make a service tech happy as he sat in my car as I ripped it up)! But in any case they suspected it to be a loose rock or gravel in the heat shield and raised the car and cleaned out my heat shields for me. So far the noise hasn't come back (knock on wood)!
Old Jun 28, 2004 | 10:37 AM
Reaper Man's Avatar
I'm a bad person
no it's a squeal and I'm just about positive it's the S-DAIS thing
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
Forevermore
Sep 20, 2015 01:04 PM
