SE RX-8 Forum Serving NC, SC, GA, FL, AL, TN
Service Experience - Russel Mazda Clearwater, FL
Old Jun 1, 2004 | 03:37 PM
greese's Avatar
Just picked my 8 back up from Russell. I was due for an oil change and while I was there pointed out my nasty looking headlight covers (sorry, no pics), my busted sliding console door and the metal worn off the shift ****.
They called and talked me into the 7500 mile service. I am at 8500 miles so this seemed like a good idea. From what I can tell, all the 7500 mile service does is add a tire rotate and balance to the oil change.
They changed the headlight covers under warranty and ordered a new shift **** and console door. Take care of your headlight covers. Those would have cost $750 if they hadn't covered them.
They were really nice about all of it. They probably could have told me too bad on the shift **** but they didn't.
This is my second time in for Service at Russell and both times I have had a really good experience. I figured since everyone is so quick to post bad experiences, that I should post when I have a good experience as well.
My only minus is that the sticker they put in for the oil change reminder says I am due again in 3000 miles. The manual says otherwise. They should know this (or else they don't care).
greese
Old Jun 1, 2004 | 03:43 PM
guy321's Avatar
Humpin legs and takin nam
Check your door, they probably gave you the M flash too!
I have VERY good experiences with Russell. I just got an oil change there Friday, and brought in the TSB for the M flash and they did it.. also Changed my plugs because I had a random misfire.. They changed my tranny out without problem!
I saw another forum member there at the same time and they gave him the M flash also.
Old Jun 1, 2004 | 03:55 PM
greese's Avatar
Where on the door? I'll have to check that when i go home tonight. I have notcied that they prefer to give you a ride somewhere rather than give out a loaner but that doesn't bother me too much. They dropped me off and picked me up from work.
Old Jun 1, 2004 | 03:58 PM
guy321's Avatar
On the driver's side.. Next to the dash on the frame of the car..
I've gotten loaners every time.. you just have to call a day or two in advance and tell them you need one..
So far, I had:
Bravado
Miata
millinium
protoge
Old Jun 2, 2004 | 07:14 AM
greese's Avatar
nothing in that spot on my car. Seems to drive the same as it did before. The rides a little different but the tire rotation and pressure adjustment on the tires will do that. Power feels the same.
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
rotor001
Jan 16, 2016 11:27 PM
Azki23
Aug 26, 2015 11:29 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
